Question about Garden
What fuel do i put in my jcb-plt25 strimer and where can i get a manual from
Jcb plt25 fuel tank parts
At a store that sells garden machines. Take the line you need with you as there are various size fuel lines.
Aug 17, 2014 | Garden
Fuel mixture for mcculloch mt 280 strimer
Fuel mixtures can be viewed at the included links.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jan 22, 2014 | McCulloch Lawn Care: Trimmer Plus...
Missing figures from JCB brushcutter manual
figures cannot be found as such. you can look for new manual.
Search Results
Jul 12, 2013 | Garden
What is D002 fault code in JCB 531-70
Water in fuel detected. Drain the bowl on fuel filter or filters. Either drain off water from tank or add conditioner. I usually put new fuel filters on instrad of just draining. Good luck
Mar 24, 2013 | Cell Phones
Need a user manual for JCB toughphone TP909
http://luputech.com/luputech/jcb-toughphone/manualer/
hi Here you can find the Instruction manual for all JCB Phones, Pro smart is in swedish, but u can use google translate ;)
Jul 17, 2012 | HP Jcb Toughphone Pro-Smart Ip67 Tp909...
WITH REGARD TO STRIMER MODEL GL652 TYPE 2 THE WIRE SEEMS TO FEED OUT ALL THE TIME THE STRIMER IS USED NOT WHEN JUST REQUIRED, ANY IDEA WHAT IS WRONG?
Yes, you are winding the string on in the wrong direction. You should wind the line on in the opposite direction that the trimmer head turns while in operation.
Good Luck!
Jim
Aug 05, 2011 | Black & Decker Garden
Ryobi strimer runs for 15 minuets cut out cooles down restart half hour
your problem is most likley a fuel tank breather problem or a ignition coil is breaking down under load and heat
retest unit again with tank cap loose if it does it again ignition coil is breaking down
cheers pauly46
May 19, 2010 | Garden
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
