Question about Archos Computers & Internet
I can't get my archos 10 to.turn on even thought the battery is fully charged
    President:
  • 3,278 Answers
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on May 24, 2011
My trimmer wont start. thought it was battery put a new one in worked for a few minutes and then stopped working
your batteries aren't charging fully, check them fully charged with a volt meter,, fully charged they should have a reading of 18.5 volts, if not they are not charging, and either the batteries have used up their life, or your charger is on its way out
Jul 15, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Archos 10 netbook running xp home won't run on battery
Go to the manufacturer's support website and download the latest BIOS update for your motherboard. Follow the instructions in flashing the BIOS carefully.
Jun 04, 2010 | Computers & Internet
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Archos 704 wont turn on or charge
First, start with the easy stuff - remove the battery and press the reset button - hold down for about 10 seconds. replace the battery, attach your AC adapter and attempt to start the player. If it still won't start, you may have a damaged DC-In connector OR the charge circuit may be bad - a TI Chip on your main board sometimes goes bad - it can be replaced. Also, if the battery is absolutely dead - no charge left at all, the player will not start even with an AC adapter
Jul 03, 2009 | Archos 704 WiFi Digital Media Player
Charging
look i have the same problem it taks so mush time to charge
it and you can onliy play with it like in a 1:00 hour only what it worng
Jan 11, 2008 | Archos 605 WiFi Digital Media Player
AV700 wont even turn on
have you tried resseting the unit?
Mike
Dec 23, 2007 | Archos AV700 Digital Media Player
Battery problem
I might have got this wrong but i thought there a fix you could download from the Archos site,i had the same problem with my mate's one only got to watch 1 and a half episode of the tv series of Heroes,i also ordered a battery type charger that could give it up to 2-3 charges while you travel.
Dec 03, 2007 | Archos 604 WiFi Digital Media Player
Computers & Internet Logo
109 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
