Question about Parlux 3200 Ceramic Ionic Hair Dryer Black
My parlux 3200 hair dryer started to make a funny noise , I would like to fix it , but I don't know who I have to contact . I bought it at the hair show in Manhattan 1 year ago and I don't have any receipt or anything. Can you help me find some one that can help me fix it. Thank you
    New Friend:
Did you find the maker? can you email me who you contacted? annika_sedek@hotmail.com
Posted on Dec 08, 2012
How to fix my parlux motor that started to slow down
possibly by cleaning the hair from it .
Apr 06, 2018 | Miscellaneous
When I start my sst16 and it is running it makes a horrible clicking noise. Can someone tell me why it is doing this and how to fix it. Thank you in advance.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Mar 23, 2016 | Dryers
Best Blow Dryer 2014 How to choose?
Babyliss Pro Tourmaline Titanium 3000 Dryer Is the best blow dryer its consumer review rate 4.3 out of 5 you can get more best branded hair dryer in the world.
Best Hair Dryers 2014 Review 10 Best Hair Dryers 2014 Review Buy it for curly hair
Aug 24, 2014 | Dryers
Hair product
Talk to the manufacturer not this forum.
Aug 22, 2017 | Garmin Health & Beauty
Screen turns blue when booting
cuz it got wet!!! take out battery and use hair dryer?
Aug 12, 2012 | Samsung Solstice SGHa887
Dryer is making a loud roaring noise when on but still works fine
Hmp..Maybe there's a part of the dryer need to be fixed.. Make sure to contact the service provider of that product,,k
Jul 15, 2012 | Kenmore 800 7982 Dryer
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
After doing a few cycles the dryer would not turn on. Pressed the start button and it made a buzzing noise 2-3 times then no noise at all. After letting it cool, took the dryer apart, cleaned it out and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Dryers
Hi My dryer is working no funny noises but it trips breaker every ten minutes. Maytag MDE6800AYW
it sounds like there may be a short in the wiring of the dryer or the dryer may be drawing to much current and tripping the breaker. I would suggest turning off any other electronics you have running in or near the bathroom and see if that helps. If the problem persists i would suggest buying a new hair dry as a damaged hair dryer can easily start a fire.
Jun 17, 2011 | Dryers
Dear Philips Experts Today i bought a Phillips Flat Iron (straightener) HP8310. It's really good,but as soon as i turn it on,it produces this weird buzzing,like zzzzzzzz sound..I am going to contact...
dear dzenanica,?ΒΈ thing it is not normal,but in their instruction written by another.I think must not spoil your hair this way,because after 1 or 2 year your hair just will not!!!!
Jun 04, 2011 | Philips Phi Blk Flat Iron Ceramic Hair...
Parlux 3200 Ceramic Ionic Hair Dryer Black Logo
242 people viewed this question
Top Parlux Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Parlux Health and Beauty Expert? Answer questions, earn points and help others
