Question about Jenn-Air JED8430 Electric Cooktop
I am reinstalling the cooktop after having the counter replaced and have a question about the wiring. My wiring coming in is B/W/copper ground. The cooktop is R/W/B, so I believe the correct wiring is Supply B and W to cooktop R and W (either order) and cooktop W to copper ground. Is that correct? The wiring diagram shows the white as a neutral Red and Black as lines in, but I do not have a separate neutral if the B & W supply are two legs of a 240V circuit. Thanks, Bruce Hastie
3 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
aborcass
  • 2651 Answers
SOURCE: Connecting to ground or neutral
SOMETHING DOENST SOUND RIGHT ABOUT THAT AT ALL. i would contact an electrician, would not even want to venture a guess as to whats goin on . let alone advise to hook up a ground to a nuteral and cap the nuetral.theres somehtin up there . i would call in a pro on that one
Posted on Mar 11, 2008
Voltage for ge jp326 wiring diagram
That's the correct way to hook it up. Check the wires for possible insulation missing.
Jan 04, 2012 | GE 30 in. JP340 Electric Cooktop
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
I need tio hook up a 4 wire cooktop(Bl R, W, Gr/copper to a 3 wire boat(Bl-L1, W-L2 and Gr) Can anyone help?
hi my name is mark, you need to check local electrical code before wiring cooktop. if it is allowed the white and ground/copper can be tied together with green from house. but if not allowed you will have to run a seperate white wire or new 8ga 3 wire/ with ground from breaker box. check the code first. and shut off power before you wire cooktop. thanks for your question.
Mar 13, 2009 | KitchenAid 36 in. KECC568 Electric Cooktop
Raplacing 3 wire cooktop with 4 wire cooktop
if you look in most panels the ground and the neutrals are tied to the same ground. they might be in a different location within the panel but they are common to each other. if you are concerned about having a seperate ground get yourself a ten foot, one inch diameter copper rod drive it into the ground about nine foot six inches. then mix up a strong salt water solution, about a couple of gallons and pour it around the rod. voilla, you have an independent ground. this might sound like a bunch of bull ----, but it is valid information. if you still have reservations call the building department in your town and they will verify it for you.
Jan 06, 2009 | Jenn-Air JED8230 Electric Cooktop
How to wire a jenn air cooktop JEC9530ADB
the new cooktops and ovens now have a 4th wire used for separating the ground and neutral. some new homes and remodeled homes have a 4th wire run from the circuit panel to the unit.
you dont have this but it is ok to just hook up the white and green/ground wires together. then red to red and black to black. it will work properly and thats all you have to do.
Dec 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Mar 08, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
JEC8430 ADB cooktop wiring doesn't matchup - no instructions for this situation
hook the copper and white together. DO NOT leave the white unhooked.
Nov 24, 2007 | Jenn-Air JED8430 Electric Cooktop
On Cooktop From Box
Black to Black
White to Ground
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
54 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
