Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Has your PC ever been able to recognize the Nuvi? A common problem on the Nuvi 11xx, 12xx, 13xx & 14xx are broken connections between the rear USB port and the printed circuit board. This will prevent communication between a PC and the Nuvi. It can also affect charging.
Have you tried the unit on a different PC or operating system?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
your e370 does connect via blue tooth,i know i do it,maybe reinstall your blue tooth sofware on your pc, or it could be a port conflict in your pc,but the problem is with the pc,not the phone
all available ports are not recognized? have you tried other known good usb devices on those ports?if other devices are recognized then it is an issue with the usb device you were first trying to hook. if not, then it may be the port issue or driver. so update chipset driver for your pc. use ibm's website to check for drivers of your pc.
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
This solution worked for me when I got the USB device not recognized message: http://www.infobarrel.com/USB_Port_Repair It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
