Question about Bose 901 VI Main / Stereo Speaker
I have a Marantz SR6004 Receiver that I am using for home theater. I want to use my Bose 901's for the front speakers but I want to use the EQ as well. I have a stereo receiver HK3385 that I want to use to drive the Bose. I know I will have to take the "pre-out" for the front speakers from the Marantz (i don't know where to plug them into) and hook them to either the EQ or the HK. Then from the EQ out and in's, where do they plug in? Thanks for any help you can give me.
  • jlemmond May 23, 2011
    Thank you for your answer. It seems simple enough and I will try it this evening as soon as I get home from work. I will be using the EQ that came with the Bose 901's.
    In using the hook up you provided, what mode will the HK amp need to be in to make this work since we are only feeding into the "main in" or will that matter?
  • jlemmond May 24, 2011
    The solution was right on, I have asked this question to other (so called) experts and never got a straight answer. Those that did answer had me stringing together several cables and changing menu settings etc... This answer was to the point and it only took me 5 minutes to do it. Keep up the great work.
    President:
  • 1,851 Answers
The things are simple. Let's try to clear them up. From the pre-out of the Marantz SR6004 you have to feed the signal to the Harman Kardon 3385 main-amplifier inputs and from the HK3385 speakers out you have to feed the signal to the Bose speakers. If you want to use an external equalizer you can connect the cables from SR6004 to the inputs of the equalizer and the cables from HK3385 main-amplifier inputs to the equalizer outputs. For all these connections except the speakers one you will use RCA cables like these. The quality - cost of these cables is up to you to decide, since the difference in audio quality between the cheap cables and the expensive ones is not very big and most of the users can't listen the difference. In the following picture I tried to create a drawing for your equipment, including the equalizer option:
If you have a particular equalizer to use, just post me model / brand to give you more connection details.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 23, 2011
  • 2 more comments
  • Stelios
    Stelios May 23, 2011
    You will have to use the STEREO (left - right) mode at the Harman Kardon. You will use this amplifier just for the front speakers. There has to be no problem using the Bose 901 original equalizers.
    In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. I'll be back "on line" after 8-9 hours time.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
  • Stelios
    Since you are going to use your official Bose 901 equalizer, here is an updated drawing for these equalizer:
    Thanks and regards
    Stelios
  • Stelios
    Stelios May 24, 2011
    Thanks for your comments. I'll be glad to help you again, whenever you need it.
    Regards
    Stelios
  • edgar129
    edgar129 Nov 18, 2012
    i m runnig marantz 6004 with two 901 serie 3, withou any centerspreaker, additionally line array of 4 bose 901 speakersers as the sitespeaker and 4 901 speakers ar rear . . .and i love it, for cinema as well as for music
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
I just bought used bose 901 series six speakers, hooked them up and they sound great. I was using bose bookshelf speakers before now. If I wanted to reconnect them for a home theater connection, without...
http://worldwide.bose.com/productsupport/en_us/web/901_series6/page.html
If your system is equipped with a tape monitor loop, you can switch the EQ out of the circuit by disengaging the tape monitor switch. If the EQ is connected to the pre-out / main-in jumper, you would have to defeat the EQ before you hook up a conventional speaker. I don't believe the EQ has a defeat switch - you'd have to rig a bypass.
Once defeated, if you have a system equipped with a Speaker A / Speaker B selector, the smaller speakers could hook up to the second system. If that's not possible, speaker switches are available for reasonable money. It is very important, though, that the 901 EQ i defeated when using conventional loudspeakers.
Jan 22, 2011 | Bose 901 VI Main / Stereo Speaker
I want to connect the Bose 901 speakers and accompanying equalizer to a modern home theater receiver.
Short answer from personal experience.
If you have Front Left and Right Pre-outs, you CAN swing it by getting a separate power amp for the 901's. Connect the EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
If you don't have the between-speaker room for proper reflection off the front wall you CAN turn them around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Dec 20, 2010 | Bose 901 VI Main / Stereo Speaker
Compatable receiver list for Bose 901 series VI
I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
I have the list in a pdf document but do not see a way to attach it.
Contact me at danmc@uwyo.edu and I'll forward the pdf.
1-30-2009
Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
Marantz sr8002
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Nov 01, 2008 | Bose 901 VI Main / Stereo Speaker
TX-SV525 Onkyo Receiver
NOOOOOOOOOOOOO!!! If you have the room for them to run free and loud, keep the 901's in service. Get them a good amplifier because any multichannel receiver can't deal with their special EQ needs and still drive conventional speakers for the other channels properly.
The good news. I have a setup similar to what I think you're trying to do and it works great! Get a receiver that has has 5.1 analog Outputs so you could drive up to 6 external amplifiers if you want to (I drive 4). Then you can draw off the Front L&R to a separate amp for the 901's and the 'other' (lesser) speakers can live on the receiver's native amplifiers.
A separate multi-channel amp for the 901's was my solution. Because I can run each channel independently to an external amp, I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers (DBX DB-SW 15's) and the Rear Surround channel (Bose 301), with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center (Kenwood 777's) and Surround speakers (Bose 301's) from its own amps.
** Multi-CH Receiver L&R Audio Out ***) >>> Bose EQ Amplifer IN, then
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Any modern AV Receiver with the pre-requisite analog outputs should work. Since you have to buy a power amp for your 901 front channels anyway the receiver need not be a powerhouse. Look for features and lots of connections for digital and analog devices. I lean toward coaxial digital connectors because A) they take standard >> and cheap << audio cables; and B) they can be shared with Y-connectors if you're careful to have only one digital device turned on at a time. Optical SP/DIF is an expensive farce to get into your wallet.
For DVD/Cable Box/Blu-Ray look for multiple HDMI or component connections. Again, length and cable cost made me look at the component connections vs HDMI and I was pleased that I can't see the difference even with HD programming from my cable box. It's all great.
Feb 08, 2008 | Onkyo TX-DS595 Receiver
Bose speakers 800
I' ve just sold 2 pairs of 800's. The buyer(who once owned a music business) used an 802 controller to test them. He said that any bose eq would do the job with no problems.
Jan 01, 2008 | Yamaha Emx88s Powered PA Mixer System
Bose 901 VI Main / Stereo Speaker Logo
1,078 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
