Question about Music
My amp has no volume unless turned all the way up and only on the high input jack
    Sergeant:
    Novelist:
  • 159 Answers
Check the "Gain" on the instrument you are plugging in ... if it is all the way down, that's the problem. If that's not it, check for a "Gain" control on the amp itself -- the is a volume control that takes care of the sound BEFORE it goes through the amp (pre-distortion etc.). Sometimes this is not with all of the other controls on the amp, so look carefully.
If it is not the gain on your instrument, and it is not the gain on the amp, then make sure you are not using too long of a wire to connect the two things. If you are using a 100ft cord to connect a guitar to an amp, there will be a lot of signal degradation in the wire, and it will be hard to get good volume from the amp since it is not getting enough signal to amplify.Try a shorter cord, and that might help ...
If all of these have failed, check the fuses on your amp. If there is a blown fuse anywhere, then your amp might not be getting the full power that it needs to produce the sound you are looking for (though a blown fuse usually cuts out ALL power through the amp, some models are built differently and this could cause your issue)
If none of these solutions work, try hooking the amp up to something else that you know works fine, to make sure it is the amp itself, not what you are hooking into it, that is not working right.
If all of this turns out to be an Epic Fail ... try speaking with customer service at the amp's manufacturer ... it might be a defect that they have seen before, and they may replace it, or at least give you a better solution that what I have done.
Posted on May 24, 2011
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Dec 02, 2013 | Peavey Music
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I have a marshall mg100hdfx head. it was working fine and I turned it on it started screaming like feedback at full volume. it does this with all volume at zero and without anything plugged in the inp
This could be many things and unless you are electronically adept it is unlikely you can DIY the repair... HOWEVER I want you to try one thing first: Sometimes the contacts on the switches of the Effects send and return go bad leaving the input to the power amp section floating and it can feedback. To test this, plug an INSTRUMENT cable between the send and return effects jacks on the back. This bypasses the contacts, If the amp behaves, you could run it this way getting a short cable or have the amp worked on at a shop to replace the jack. The jacks are really rather poor quality on musical amps in general.
May 13, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hooking up the speaker to an amp, using the rca line out of the amp i have no volume control from the amp knobs, can i hook the speakers up to the amp from the speaker out ?
You should NOT under any circumstances connect an audio input lead to a speaker output jack!
The RCA jacks you are trying to take output from ore "pre fader" which would be solid "line level" and not controlled by volume controls. Tap off the INPUT to the amp... you should be using balanced lines for the interconnects. RCA jacks are unbalanced lines. You can drive several inputs from a line level output of a mixer for example using a splitter cable.
Aug 23, 2011 | Harbinger APS12 12 Powered PA Speaker
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
WHAT TYPE OF AMP?
Probably the easiest way would be to use a stereo receiver. You can run the headphone output of your ipod into a tape or cd input. The only thing to deal with will be adapting a stereo 1/8" (3.5mm) headphone type jack to 2 RCA type input jacks. You should be able to get this cord at radio shack. You might also be able to purchase a receiver that has a 1/8" input jack specifically for connecting things like an ipod. A receiver, by definition, has a tuner built into it. The alternative would be a tuner and an 'integrated amplifier' which has power amps to drive speakers as well as a pre-amp and input selection switching.
Feb 28, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
88 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
