Hi, My TimeGuard ETU2000 water immenser doesn't work. The display is OK, it says the immenser is on when it has to be, yet the wee red light doesn't light up whatever I do and whatever the program is. The battery might need to be replaced. How could I do that? Cheers! Tamas
  • 7 Answers
SOURCE: spilt water on mouse. Now red light on
if the mouse is working properly then you might just want to leave it, is it a rechargable mouse?
If you do want to try and fix it , you could try carefully opening it, you should not need to use much if any force and then make sure everything inside is dry, using a hairdryer on low heat can be useful.
there is a chance the water has damaged the electronics of the mouse and so you might not be able to fix the problem.
Posted on Nov 06, 2009
SOURCE: My Timeguard ETU2000 timer sometimes seems to get
hi there im having problems with my timer imersion and came here looking for awnser of my own lol any hows just seen your question and if you want to reset the unit completly ive found that press and hold the black setting button in at the same time hold the white program button in so basic hold both buttons in at the same time watch the screen display and you will see it display all the digit featuers when you see that release and its reset hope this helps you
regards mike
Posted on Jan 26, 2010
bhowell786
  • 88 Answers
SOURCE: the remote battery died and after replacing it the
The remote needs to be programmed when the battery get's replaced. You will most likely have to take it to a dealer to have it done.
Posted on May 26, 2011
Testimonial: "thanks for your help i'll try that."
  • 17 Answers
SOURCE: Hi, My g. door opener doesn't work. The
5 Blinks on the logic board LED indicates that possibly the motor has overheated. If you have unplugged the unit and waited minimum of 30minutes before plugging it back in, and it still will not operate, then the logic board will need to be replaced.
I hope this helps
Posted on May 27, 2011
bugoy31
  • 1238 Answers
SOURCE: Eton soulra plugged in no
Good day!!!
Test it.try to open it then tell me what is your observation...
So that I can give a better solution.
Also look at the charger if there is any worn out or loosen connection because it maybe causing of defective charger.
For you to make sure try to find a charger the same with yours and charge it to test if it is charging and open it...
NOTE: I need all your observations so observe it properly after testing all the said things above and have a comment.
Thank you!!!
Posted on Aug 15, 2011
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
PS3 3D TV Display Doesn't turn on 2 red blinking lights
HI, in this video you will find how to fix your Sony 3D Display
https://www.youtube.com/watch?v=OdPGSZnTIPw
Dec 02, 2012 | Sony PlayStation Televison & Video
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
Washer won't start. Power is on, pressed power, then pressed permanent press, then water temp, then start. There is a red light on spin cycle and it just beeps and doesn't start.
Hi - if that red led light comes on as you press start - then the display module is faulty - however it's not always the case - often its the motor controller module thats faulty..
Your call - display module first and hope it works or controller.
The manufacturers recommended procedure is to replace the display module (primary) if it still doesnt work then replace the control module (secondary).
Cheers
Jun 27, 2011 | Fisher and Paykel GWL11 Top Load Washer
Windows server 2003 hd red light and beep
According to you your server doesn't work properly and you get a beep sound and a still HD led, OK don't worry.In this situation I think you don't get display also. Anyways, first unscrew your system and open the panel of the cabinet. Then unlock the memory slot holder, take out the memory/Ram. make it clear by eraser. clean the metallic chip which is attach with slot. after that replace it again in same or other slot carefully by a little push. notice the notch of the Ram while replace it. It will solve your problem.
Apr 28, 2011 | Dell PowerEdge 1600SC Server
How to set up a time guard ETU2000 timer
Looking for some help with my TimeGuard ETU2000. I'm not getting any hot water whatsoever, tried boost, reset, resetting timed hot water all that but still no hot water, in fact I kept the main switch button so that it heats up water but no joy till date. Please advice anybody out there..
Nov 08, 2010 | Heating & Cooling
My Timeguard ETU2000 timer sometimes seems to get lost and continually switches on/off. This seems to happen after I use the 1hr or 2hr or continuous on functions. Does anyone know how to reset this...
regards mike
Sep 18, 2009 | Hardware & Accessories
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
