Question about Canon D320 imageCLASS Digital Copier
I have a Canon D320 copier that is leaving roller marks on the copy.How do I clean the rollers? Is there any way to remove said rollers?
  • 30 Answers
You may need to remove the paper tray to access the rollers. There is usually a clip on one end of the roller that holds it onto a rod. You can clean the rollers with an alcohol pad, it may not even be necessary to remove them.I hope this helps, keep me posted!
Posted on May 24, 2011
I have a Cannon D320. Copies have roller marks on them. Can I clean rollers. Roller mark is in center of page top to bottom.
each and every machine needs to have a technician responsible for servicing and maintenance.
If you know where the marks are coming from then you can clean, because they mighty be coming from the drum and from the drum you just have to replace and not clean.
if from the fixing assembly need to consider:
1. if pressure roller or upper roller/fume does it have dirty or it is damaged when damaged need to be replaced if dirty, clean while it is hot with silicon oil(heat resistant).
Jul 14, 2011 | Canon imageCLASS D320 Digital Copier
How do you take out a paper jam canon ImageCLASS D320?
First you have to know the position of the paper that has jamed.
the cardinal thing to do is to loosen and open doors that must be opened in order to have a clear view of the paper.
How to open see the marks on the machine. Mainly the paper jams between the drum and the fuser, so make sure you see any green nobs meant for seperating the presssure roller and the upper roller so that the paper is free to move out in case it jamed between the fixing rollers.
See the manual on how to remove paper jams.
Jul 12, 2011 | Canon imageCLASS D320 Digital Copier
Copies come out with what looks like a water mark down the entire page on the right hand side.
Hi; Simply, you must clean the unit of devthe eveloppent with a vacuum cleaner, and especially The Transfer roller, what you have is a cause of the toner from the magnetic roller.
Oct 13, 2010 | Canon imageCLASS D320 Digital Copier
Changed toner cartridge and still not printing entire page- mostly white space. How can I tell if it is a faulty new cartridge or problems with my copier. There is toner dust inside the copier from when...
First you need to vacume the spilled toner, especially on transfer roller, eaven clean the transfer roller contacts.
Try to reinstall the old crg., shake it so that you may get few copies for checking it. If print is OK then its problem in new crg.
Feb 23, 2010 | Canon imageCLASS D320 Digital Copier
Copier make squeky sound while making copies...
Whatever you do, DO NOT PUT OIL ANYWHERE ON THE COPIER!!!
The rollers are wearing out; you will have to call Canon to send a tech, or, if you are a qualified Canon Tech or have one in your office, have them look at it and order the necessary parts.
Oct 07, 2009 | Canon imageCLASS D320 Digital Copier
Canonimageclass D320 makes smudged copies. What do I do?
This model is noted for a jam in the fuser area around the roller, Not easy to get to but sounds a like that may be proble, Can you hear a sound like paper wrinking as it runs. Also is the drum in the cartridge clean or has tone on it. Have you changed the cartridge. I do get a kick out of Staples Experts.. They did sell you some cleaning sheets... Hey Good Luck....
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Apr 10, 2009 | Canon IMAGERUNNER 6570 Copier
I think the transfer roller is damaged
Yes - it probably is the transfer roller. the P# is RG0-1025
Jun 09, 2008 | Canon PC-D320 Copier
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
250 people viewed this question
old marine
old marine
