Bosch W125 KV 3P 32 s 3104T1 Hi This is a tankless HW propane heater that is used up at my cottage. The issue I am having is that the main burners are not igniting. As well there seems to be some water flow restriction through the unit. I had a look at the water strainer and it seems pretty clogged. I am assuming that this is the source of the water restriction. My question is what would be causing the heating elements not to ignite? Please let me know Thanks Cain
  • 49 Answers
SOURCE: Weather King AC/Heat Pump - Electric unit, Model 14AHJ11S01C01
Your evap coil in your indoor unit should not develop ice in the heat mode. It sounds like your reversing valve may be stuck in the cool mode, not allowing your heat function to work. If it is cool where you are you may need to use your emergency or auxillary heat function until your problem is resolved.
Posted on Nov 28, 2007
jfpogie
  • 104 Answers
SOURCE: Rheem heater will not work
seems like you have a defective heater.
Posted on Jan 24, 2008
  • 230 Answers
SOURCE: I have an Bosch AQ125-HX
The first thing I would do is to clean the unit out. The instructions for this is in your manual. Sometimes this is just a matter of things getting clogged up and limiting the flow. The flow sensor itself may also be plugged up making it more difficult to sense the flow of water. The process for cleaning these things is really quite simple. It does take a little time though. You will probably need a bucket, Two hoses, and some food grade white vinegar. If this does not work, just let us know. Good Luck!
Posted on Jun 30, 2008
22yooper
  • 828 Answers
SOURCE: 2001 Coleman Niagara Elite folding
You may have one of two problems; The pilot orifice is very small and allows only a limited flow and any air trapped in the gas supply takes some time to bleed out while you are holding down the pilot button. Or the pilot orifice may be plugged in which case you would have to replace it.
Posted on Jul 10, 2008
  • 92 Answers
SOURCE: Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Posted on Apr 15, 2009
Where can I download a Boschw14 b31 gas Heater Manual
Is this a water heater? Bosch site might have manual. And service bulletins, but I have not heard of that model.
http://www.bosch-climate.us/Bosch-Hot-Water/
Call local service technician who is qualified to work on tankless computer that heats water.
You can fix any brand tankless computer, any problem, same day, yourself by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
l
Aug 05, 2013 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch aquastar wont get hot
1) If tankless is not showing error code, the problem might be single-handled faucet cartridge:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
2) Catch up on maintenance, such as cleaning combustion parts, have gas pressure checked, etc.
Feb 20, 2013 | Bosch AquaStar Natural Gas Tankless Water...
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Aqua star runs on and was running water to out side I guess it would be the overflow ( tankless). Had to turn the water off
Problem is not clear
Before calling service technician, open following link for Bosch troubleshooting resources including contact information for Bosch:
Jun 09, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Bosch Aquastar tankless water heater model 1600P Pilot is lit but main burner will not lite. replace water valve that controls ignition.
There should be a thermocoupler, it is that bulb that sits in the pilot flame. If it is not functioning properly the main gas valve will not open.. Hmmm, Is the main valve in the on position?
Oct 10, 2009 | Bosch AquaStar 1600P-LP 1600P Liquid...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Mar 16, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
