I have the Saitek Rudder Pedals, the Saitek Throttle Quadrant and the Saitek Flight Yoke. I tried to install the brakes on the rudder pedals.and the prop control and mixture on the levers that have other controls on them, the third lever is ok as it is. I went by the directions in the manual but it did not change anything. Jim masucci
    Genius:
  • 1,400 Answers
Hello
I don't know what flight sim your using with this . I had a similar problem with flight simulator.
I wanted my piper arrow to work like the real thing as i was preparing for my commercial pilots ticket.
Gump. Gear undercarriage mixture prop.Anyway what i did was delete any key binds within the control setup options in the program your using.Then Assign your saitek rudder pedals to the area deleted.
In other words if key B were brakes in flight simulator,delete it and put axis xyz or whatever from your Rudder pedals in place of it.
Be sure your controls are calibrated within windows first.
Posted on May 24, 2011
Loaded XPlane 10 on new iMac and rudder pedals no longer function?
My iMac has a CD/DVD drive, but I posted a X-Plane 10 pendrive to avoid inserting DVD #1 every session. It functions perfectly. Another point is to connect all peripherals (stick and pedals etc.) BEFORE launching X-Plane 10. Then calibrate your peripherals within XP 10.
I have no pedals set, but instead a pitch-stick with grip throttle and a Logitech joystick with twist grip to fly helicopters.
Jul 29, 2014 | Saitek Pz35 Pc Pro Flight Rudder Pedals
CH Flightsim Yoke Sensitivity
Have you tried adjusting the sensitivities of each axis using the Control Manager?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 26, 2008 | Video Game Consoles & Games
I have just bought a Pro Flight yoke and throttle system it has a computer cd with it my question is this...Do you put in the disc just before loading up the yoke and throttle system??
How to Set Up a Saitek Proflight Yoke System Instructions
    Mounting the Yoke
Mounting the Yoke
  1. Determine where you will set it up. You need a desk or table with a wide, flat surface. Clear away objects on the desk that might be in the way or that could be accidentally knocked off. The yoke must be mounted on top of the table and takes up a good deal of space, but the throttle may be mounted in front of or even under under the table if you prefer.
  2. Remove both units from the box carefully. The system is lightweight, but care should be taken not to drop it. Note that there are also some loose parts in the box including the large clamp which attaches the yoke and a smaller clamp for the throttle unit. Note that there are some instructions and diagrams on the back of the box that may be of use.
  3. Place the yoke on the surface and position it where you want it.
  4. Pick up the yoke clamp assembly and make sure that the threaded plastic bolt is inserted, but not screwed in. The clamp fits underneath the table with the two upper prongs sliding into the corresponding holes on the front of the unit.
  5. Adjust the yoke and clamp as needed to insure it is in the exact position you want. Then tighten the plastic bolt. Test the yoke to make sure it is stable and does not move on the table when you manipulate the controls.
  6. Pick up the throttle unit and its clamp assembly. Unlike with the yoke, the clamp assembly must be screwed into the back of the throttle unit using small screws. Note that it may be attached in two different directions depending upon how you wish to mount the throttle to your table (either above or in front of it). Decide now which way will work best for you. See the images on the box for reference.
  7. Position the throttle clamp around the table surface and tighten the plastic bolt, just as you did for the yoke.
  8. Connecting it to Your Computer
  9. Look at the back of the yoke. There is a single USB cable which is permanently attached to the yoke. Plug this cable directly into a USB port on your PC. The ports on the rear of a computer usually work better for this purpose than those on the front.
  10. Look at the back of the throttle unit. There should be a single cord coming out the back of it. Note that it is not a USB cable. Instead it has a round connector, like those used on non-USB keyboards and mice. Plug this cable into the round port on the back of the yoke.
  11. Turn your computer on. It should recognize the yoke as a new plug and play device. Note that the computer will see the yoke and throttle as a single device rather than as two separate ones. The included software is not required. The yoke should work as soon as it is plugged in.
  12. Go to website http://saitek.com/uk/down/drivers.php to download and install the latest drivers.
  13. Assign buttons and commands directly through your favorite flight simulator.
  14. Additional peripherals such as rudder pedals or another throttle unit may be added using the USB port on the back of the yoke.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Dec 14, 2010 | Saitek Pro Flight Yoke System Flight...
Saitek Pro Flight yoke and quadrant stop working
I had a similar problem with Vista Home 32. Finally tried an old external USB 1.1 hub that I had laying around and now everything works all the time in FSX and X-Plane. It is rock solid. Can't make it fail even when I try. I also tried a USB 2.0 hub but had the same problem with that. I can't say for sure it will fix your problem but it is worth a try.
Oct 30, 2009 | Saitek Pro Flight Yoke System Flight...
Hi, I contacted Saitek approximately 2weeks ago regarding the blueand purple backlight failure on my Eclipse II keyboard. I am awaiting your reply. I now have, what I feel to be a more serious failure on...
Hi Chris
Ensure that you have the usb lead from the yoke plugged into the rear of the PC as these give the most current. Ensure the drivers for the yoke are installed properly and they are the latest for your operating system. If this still does not work, then the yoke is faulty. Good luck!
Jul 23, 2009 | Saitek Pro Flight Yoke System Flight...
Twist Rudder feature interferes with use of rudder pedals.
Ya you can disable it just go to menu of home page>Controls>assign A command> and disable
Jan 24, 2009 | Saitek ST290 Joystick
Rudder Twist Feature
I have the same game but what you need to do is go to the menu on the hompage of game and go to controlls and disable it. i will post more details later
Rudder control
Your in luck I happen to be a Flight simmer also. You need to go into your main menu under settings in Flight sim 2002. You will see enable joystick then you will see cordinated flight or uncordinated flight. You want to select uncordinated flight. Meaning that you will have full control of rudder and the sim will no longer make coordinated turns for you. You will have to add rudder to prevent a skid.
Sep 19, 2007 | Saitek CYBORG EVO FORCE Joystick
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
