Question about Frigidaire Electric Dryer
I have a front loader fridgidaire dryer its a couple yrs old today when i put clothes in it to dry i usually hit the start button and then hit the start button again to start it but today I did it just like normal and when i hit it the second time all the lights on it beep a few times but it does not turn on i checked the belt and unplugged it and still nothing can someone please help I have 4 kids and the clothes are never ending around here thanks
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 26, 2011
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer stopped 1/2 way through cycle-hit start, drum won't turn
if the unit is sounding like it is struggling to start then you most likely have a bad bearing in the motor. they will usually get noisy and the become worse and louder. the unit also will run for awhile and then stop with the clothes not dry, if you try to start it it will go but will stop again shortly later.
if this unit is fairly old, like more then 10 years, you might want to look at the price of a new unit versus replacing the motor. the motor could cost you about 100-120 bucks if you put it in yourself and another 100 bucks if you pay someone to put it in for you. most new dryers will cost about 250-300 bucks, so the choice is up to you.
Dec 27, 2008 | Kenmore 63942 Dryer
Can I make the water level on my whirlpool duet washer higher?
its because of the design of the machine they are water efficient.a front load uses any where from 15 to 18 gals. compared to 40 to 50 gals.for a top load. they also have a higher spin rate than the top loader,therefore making your close dryer and having a less drying time in the dryer.energy efficient too!!
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
GE front load dryer
Clothing gets caught in the front of the dryer as it spins. This is leaving black marks and wholes in our clothing.
Apr 06, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
Washing machine spin cycle
chances are the pump may have something in it or the drain line is kinked a little front loader machines have a clean out on the pump that you can get to buy taking the lower front panel off.top loaders you have to pull access cover in the rear and pull hose off and check for blockage also check belt tension and quality of belt
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Frigidaire  Electric Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
