What would it cost approximately to repair this color wheel, ballast and lamp on a 52" samsung rear projection...is it worth it...
    Genius:
  • 1,011 Answers
Dear,
ask this for the customer care centre, they will better guide you exactly, not approximately.
regards,
rate it, if u feel its functional
Posted on Aug 15, 2008
Samsung HLR5067WX DLP - No picture, lamp light flashing
The colour wheel will not spin until the light has lit. The light will not ignite if the ballast unit detects a faulty fan, (checked) or the lamp door is open. The processor must be working as the lamp light flashes so I would say, ballast especialy if the lamp that came out is physically broken. Not cheap, even from flea bay!
Dec 06, 2013 | Televison & Video
I heard a "pop".
HD50LPW62 is Not projection,Projection TVs have 3 Tubes R/G/B.
Your TV is DLP which has Lamp and Color wheel, Ballast board, Lamp Fan.
You need to Check the Lamp,You will need to remove the back in order to see the Lamp.
Lamps are easy to replace.
Mats Electronics has Lamps 1-800-628-1118
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
After a loud pop, TV made loud noise and kept trying to "reboot." We replaced the color wheel (shattered) and projector lamp (which had a crack). When I turn it on now the Lamp light blinks.
I would say the next thing to replace would be the ballast for the lamp and if that does not work the power supply board may have failed. When I replace the power supply, I also replace the ballast at the same time.
Jun 01, 2011 | Samsung HL-R4667W Rear Projection...
Replaced lamp, would not come on , Got a loud, low pitched buzzing noise.
The color wheel on the set is bad and that is what is causing the buzzing. This unfortunatly is common.
It can be the lamp. But the color wheel and ballast can cause the same thing. Put your ear to the back of the set when you push the power button and you should can here the color wheel start up. If not, that is your problem.
Now if the lamp is not lighting up. you should here a ticking sound from the back of the set, if not the ballast is bad. If the lamp is coming on and then going out after only about 5 seconds AND you do not here the start up of the color wheel, the color wheel is confirmed bad.
Below is a link to the a service manual you can buy and have it shipped to your home if you want to try the repair yourself.
http://servicemanuals.vstore.ca/
Apr 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Jun 04, 2010 | Samsung HLP6163W 61" Rear Projection...
My WD-52525 started a rubbing noise coming from the back area. I figure it's the light engine. Color was off and it won't restart, has a lamp light now. Lamp is 4 months old. Sound like light engine?
This sounds like your color wheel. this will affect the colors on your screen. Do check your lamp though, at 4 months you still should have a good lamp. Unless you have a bad ballast affecting the lamp as well. If you hear a rapid clicking or an electrical buzzing type noise. "ballast"
Apr 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The tv makes a loud noise - timer/lamp lights light up but no picture/sound. Changed bulb - tv worked for a short while. Now issues starting all over again. What could be causing this?
Ballast Board that connects to Lamp it could be bad or recheck to make sure its pluged in good anyway Ballast Board is what turns Lamp on Loud Noise means Color Wheel which can also shut set off Id say Color Wheel Call Encompass Parts 1-800-638-3328 they List all the Parts you need Part# for color wheel is BP96-00674A cost 129.69 They also have Service Maualfor your TV. Also Look on E-Bay under Electronics found some good deals thier Got my Lamp for 85.00 and Ballast Board for 65.00
Nov 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I need your help with my DLP TV
YOU PROBABLY NEED A DMD BOARD. THE COST OF THE BOARD IS $900 . YOU CAN GET A LIGHT ENGINE FOR $700 THAT HAS A NEW LAMP, COLOR WHEEL, BALLAST AND DMD.
WHAT A DEAL . THERE IS A $400 CORE ON IT SO YOU WILL HAVE TO SEND BACK YOUR NEW BALLAST AND LAMP TO GET THE CREDIT BACK.
WHEN I GIVE A QUOTE ON THESE SETS FOR REPAIR MOST OF THE TIME IT EXCEEDS THE VALUE OF GETTING A NEWER BETTER SET.
DON.
Jun 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Turn off by itself
1)Lamp
2)Color wheel
3)Lamp Ballast
4)Complete engine replacement
Locate a servicer who has all parts possible on board his truck.
Ask what a diagnostic service call/repair would cost.
Oct 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
