Question about Fossil Twist Black Dial Watch for Men
Ladies Automatic Movement With date ,The watch will not wind wth the crown or by shaking the watch.Second hand never moves.
    President:
  • 2,501 Answers
It sounds as if your watch is in need of some TLC by a watch repairer. (I assume that it is not under warranty; if it is, go to Fossil.com and click on customer service in the menu at the bottom of the page).
Have you dropped it onto a hard surface?
If the watch is several years old, then cleaning might help.
I suggest you take it to a local watch repairer and ask him to look at it and advise you on what needs to be done.
Posted on May 24, 2011
Just a quick question On my Omega Double eagle, I went to mexico for the week left my watch at home and when I return I gave it a shake to start the movement being it is a chroncile watch and for some...
A mechanical watch will tend to stop in the same place if an internal gear is slightly unbalanced and/or there's a spot of grease/dirt that makes that particular point on a gear slightly more difficult to pass. I've often seen watches with day/date indicators stop just around midnight, as it takes more energy to advance those dials than just move the hour and minute hands.
Try winding your watch with the crown as opposed to shaking it to wind it via the automatic rotor. Actual winding will bring your mainspring up to full power much faster than a whole lot of winding via automatic rotor. See if this changes the behavior of the watch. If it doesn't, you probably need to have a watchmaker take a look at the watch. He or she will probably recommend cleaning the movement to clear any dirt that might be causing the problem.
May 08, 2011 | Omega Constellation Double Eagle Gold &...
I was given a Tissot Seastar and I know nothing about it or if it's worth fixing. It has a 17 jewel automatic movement which works fine.It also has the day and date. The movement number is 14190996 and the...
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
Apr 30, 2017 | Tissot Watches
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Watch is new out of the box. Movement will not start. ???
mcdevito75 here, If your Wittnauer is a Quartz movement, look for a small piece of plastic, just under the crown (winder) remove this piece of plastic carefully and push the crown back down to start your watch, if it's an automatic movement, try to wind with the stem if you feel a resistance then winding will initially start yor watch by winding with 20--30 winds, if you feel no resistance when winding the simply rock your watch back and forth in your hand, you will detect something moveing inside the watch, this is the counter balance winding the watch, rock the watch back and forth for approx. 30 seconds to start an initial wind.
Jul 10, 2010 | Wittnauer Belasco 36 Diamond 27 Mm Watch...
I have a Croton watch. It is a automatic.I can't get it to run.I was informed that the watch had to be wound. The crown{stem} has four settings.I shak it and it runs for about 15 seconds
In the first position (closest to the case but not screwed down if it's a screwdown crown) wind the crown clockwise about 40 turns and it should run fine. The automatic winding system relies on wrist movement to spin a weighted rotor that winds the watch. When you're not wearing the watch or not moving much when you do have it on, it will run down and you have to manually wind it to get it going again. If you wear it everyday and are reasonably active you may never have to wind it but take it off for a day and you will.
Apr 20, 2010 | Croton Automatic Watch Day/Date Swiss...
Need to adjust or move date forward
Hi
Thanks for using FixYa. To adjust the date and time you’ll need to follow these instructions---
To wind the Movement:
With the crown in position 1, flush against the case, turn the crown
clockwise, completing approximately 15 to 20 revolutions, then
gently but quickly move the watch back and forth several times to
start movement.
To set the Time:
Once the watch is running, pull the crown out to position 2 and turn
it in either direction to set hands to desired time, then push crown
back in to position 1.
For more information you can see this manual---
Tommy Watches Operating Instructions
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 28, 2010 | Tommy Bahama Rlx1004 Relax Beach Cruiser...
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
Can't set day and second hand
For dates- pull out crown half way (first click) and by turning the crown set date. Push crown back.
For chrono setting: pull out crown halfway and using pushbuttons reset seconds hand. Push back.
If this do not work: pull out crown fully (second click) and then reset. Push back.
Dec 18, 2008 | Watches
Rolex ladies DayJust
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
May 02, 2008 | Rolex Daytona 116520 Wrist Watch
Fossil  Twist Black Dial Watch for Men Logo
118 people viewed this question
Top Fossil Watches Experts
Jimmy Accardi
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
