No lights coming on at all on a HP 530 when power supply is plugged in. I have tried 2 different power supplies but still no lights. Is this a motherboard problem and how can i test if the mother board is getting power ?
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 23, 2011
Hp 530 desktop ginen 3 and 4 red lights in start
As far as I can tell this is two errors. One error is that the processor is not plugged in properly. The other is a power supply error.
I suggest taking it to a local computer repair place to have it evaluated. Let them know you believe the power supply is failing which explains the CPU failure.
Feb 23, 2015 | HP Computers & Internet
My hp pavilion desktop pc power cable is plugged in but when I push the power button it does nothing
most of those hps have a light on the back on the power supply that lights when its plugged in but not all. I would try plugging it in on a different outlet to be sure its not a power strip or bad house socket. Make sure if it does try to come on that the power supply fan is turning. I would also take the side cover off and make sure that the wires that plug in the switch have not come loose
Dec 13, 2013 | Computers & Internet
When I plug in my HP 530 Green light comes on then turns to amber. Will not come on even when I remove battery and just plug in. 1322dijim@gmail.com
The System / Motherboard has faulty Power Circuit. Contact HP and arrange a repair. If under warranty won't cost anything.
Jul 05, 2012 | HP 530 Notebook
All lights on wont shut down wont respond
Hello, maybe you have to do what i call hard reset, unplug it from the light then look round if you can locate any fuise on the print take it off, then allow it for 1hour and try again later
May 07, 2011 | HP Deskjet F2210 InkJet Printer
My hp 530 notebook just shut off and it will not come back on. what should i do? i took out the battery and put it nack in, it didnt do anything.
Remove the main battery and plug in the power supply, now try the power button, if it won't work, the DC jack in the computer may be the problem. Plug the power supply into the laptop, now grab the plug and bend it sideways "not to hard" and press the power button repeatedly to see if the laptop will come on, if it does the jack must be resolded back on the motherboard or replaced. If after all this and there is still no change a computer technician will be needed to take it further.
Jan 11, 2011 | HP 530 Notebook
HP Deskjet 9800 will not power up. Tried replacing power cord and tried plugging into a different power outlet. The little green light on the back of the power supply unit comes on, but the printer will...
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Jul 27, 2009 | HP DeskJet 9800 InkJet Printer
HP d330 fried during pwr serge, fixed, boots but no screen signal
there are several possibilities. 1. replace the ram, make sure that its a good working ram module. 2. review all your work from system board to power supply. 3. try running it temporarily without the cmos battery. 4. check your monitor. 5. check your VGA. 6. retry and retry.
Jul 13, 2009 | HP Compaq Business Desktop dc5800
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
Hp 530 notebook flashing power light when unplugged from the power cable, even though the battery is 80% charged
hey
i had this same problem with my hp 530
i dont know if this is what you are meant to do but if u turn off the laptop and take the battery out and put it back in again the problem should stop
it may happen again a few weeks afterwards but just do the same thing
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
