Question about West Bend 6235 Deluxe Deep Fryer
Deep fryer model 770, item 9701, LR43488. How can
Deep fryer model 770, item 9701, LR43488. How can I scour this item clean? Nino Campana
I have a pitco deep fryer... Everything works fine, but when the burners go off, I get a popping sound that blows out my pilot light
It sounds like the burners and tubes may be dirty and clogged in your fryer. The burners are removable and need to be cleaned periodically. The tubes can be cleaned when the burners are out using a burner cleaning brush. If the above mentioned items appear to be clean, you may have a gas pressure issue.
Jan 08, 2013 | Kitchen Appliances - Others
What are most common problems found with pitco frialator fryers?
Some of the most common problems with Pitco fryers is failed Hi-Limit thermostats, carbon build up on burner tubes, and dirty or clogged burners. This hi-limit thermostat is mounted inside the fry tank on one of the burners. Often the cappillary tubes are damaged or broken during cleaning causing the limit to fail. The hi-limit is the most common part I replace on Pitco fryers. The other common items are self explanitory. Keep the fryer clean in all areas, including burners and tubes. You will see the repair man less often.
Feb 09, 2011 | Pitco Frialator SG14 Deep Fryer
I've lost the plug to my Rival CZF 530 deep fryer. Can I get a replacement?
Regrettably, I contacted the RIVAL company and they said they no longer support this model. Plus they stated that the item would not be sold separately. 800-557-4825 option 1
I even looked on ebay to see if someone would sell the part separately, regrettably there were no listings.
Good luck.
Sep 27, 2010 | Rival CZF530 Deep Fryer
All battered items stick to the fryer's net and
It is NOT hot enough when you FIRST drop them in, it should be hot enough so that they Float, immediately they are dropped in.
Feb 28, 2010 | Philips HD6153 Deep Fryer
We have a dean deep fryer model SR42GNS on start it makes a big boom and a large blue flame comes out of stack on top?
is the fryer propane or natrual gas?It sounds like the orfices,burners or baffles may be clogged and needs cleaning.let me know.
Apr 08, 2009 | Frymaster Dean 2424G Deep Fryer
Trying to find out the mfg of deep fryer by serial
Brand: pitco
Item: deep fryer
Model: 14c
Specs: btu110,000/
Width: 16in
Depth: 32in
Height: 54in
http://www.pitco.com/contact.htm
Good luck and Please Rate Fixya!
Mar 15, 2009 | Kitchen Appliances - Others
Rival deep fryer electric cord does not work. The fryer will hea
If you have had the product less than a year and you have not misused the item, take it back to the shop you brought it from.
as obviously it is not fit for purpose
Feb 18, 2009 | Rival CZF625 Deep Fryer
Kitchen Appliances - Others Logo
137 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
