Question about Panasonic Cell Phones
Kxtg1311e cordless phone - no dial tone and wont ring but plugged into good socket - any ideas?
  • 7 Answers
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Posted on Nov 10, 2007
  • 298 Answers
SOURCE: Phone doesn't ring, no dial tone.
Try switching the battery wilth a know to be
good battery
Posted on Dec 01, 2007
vivekvk339
  • 86 Answers
SOURCE: i have a 6600 nokia phone..
1ST U FOMET UR MOBILE AND MMC AND THEN INSTALL MP3 SOFTWARE.
Posted on Mar 03, 2008
mattozan
  • 555 Answers
SOURCE: GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
Posted on May 21, 2008
SOURCE: UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Posted on Jul 08, 2008
Panasonic cordless, no dial-tone, not ringing yet landline seems to be ok since computer is working.
although the computer and the telephone use the same line, they do not use the same system
frequency for a telephone is vastly different to adsl and it is in the exchange that the difference occurs
get ( borrow) an old phone and plug it into the socket and if you have a dial tone , it is the cordless system that is faulty
if the batteries are recommended at 1.2 vo then that is what you should be using as that is what the phone frequency will be set to use
Oct 12, 2016 | Panasonic Lands Phones
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
good battery
Dec 01, 2007 | Motorola Mobility MA 361 Cordless Phone
Please help I can't ring out on my phone
Check for dialing tone by pressing 'Talk On' phone button.
If no tone, check cord at base station and the phone socket is correctly plugged in at both ends using the original cord supplied.
If still no dial tone, check the phone at another phone connection to establish if either the phone or the line is faulty. Address for
Binatone support at this link: http://binatoneglobal.com/support/
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
Why will my uniden phones not dial out, all units will not dial out. Phone jack works, but when I try to dial, with each digit pressed I only get a dial tone. Phone will receive calls, but I cannot dial...
I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires.
This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular socket you are plugging
the base ('main unit') into.
Feb 18, 2015 | Uniden Cordless Phone
Why won't my Uniden cord or cordless phone system dial out. with each digit pressed a dial tone is heard and nothing connects.
ring' wires. This was only a problem with the
Feb 18, 2015 | Uniden Lands Phones
Why no dial tone??
have you plugged your new phones telephone line into the telephone socket?
Aug 01, 2014 | BT 4500 Cordless Phone - DECT - Satin...
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
Dec 12, 2010 | Uniden Cordless Phone
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Cell Phones Logo
121 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
