Question about Lexmark X2500 All-In-One Printer
Lexmart 3550 I have a 3550. It is new and has been fine. All of a sudden it will not let paper through the feed. It keeps saying to load paper and push the check. Nothing changes, no matter how we load paper it only goes so far. I have spend an day and a half on this. There is no paper jam. All we get is a bad click click and it grabs the paper and takes it so far and then crinkles it up. HELP this is a new machien.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
There is something stuck inside. look through intake and remove back panel, to check for trapped paper slices.
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
My Hp 3550 printer is not printing any more , the green light keep on blinking , pls help me out here
Pls do the following:-
1. Switch off the printer.
2. Feed the paper correctly.
Then try again
thank you......
Jul 22, 2011 | HP DeskJet 3550 InkJet Printer
Error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
Paper not going inside
Try to place the paper correctly...if it not means its having problem with the head...carry to the nearby hp service center and clarify it
Jul 05, 2009 | HP DeskJet 3550 InkJet Printer
Computer keeps saying "paper out" or "not loaded properly"
disconnect the printer from the computer
do a manual paper feed
if it can feed paper, replace usb cable or try another usb port
May 14, 2009 | Epson CX8400 All-In-One InkJet Printer
Paper jams lexmark x3550
You need to visually inspect the rollers. I suspect that there is a small piece of paper jamming the paper path. Check where it is jamming, and inspect.
Mar 10, 2009 | HP Color Laserjet 3550 Printer
I moved my computer and lexmark3470 to another room. suddenly i hook it back up [ports work fine} the three buttons on the left won't move up and down, and the printer keeps saying theres a computer jam...
If it shows false paper jam error try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Lexmark X2500 All-In-One Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
