Question about Nintendo Planet Puzzle League NDS DS Tetris puzzle Game for DS
Nintendo ds touch screen replacement
My bottom touch screen no longer reacts to the touch. I'm going to replace the failed part myself, but I'm not sure which part to purchase. There seems tobe the touch screen sensor( the part I think I should buy) and there is the bottom lcd screen part. They both cost the same. Are they the same part, or two different ones? Which one sould I get?
The cable from the top of the touch screen going into the slot around the back of the circit board is the cable that lets the nds know you are touching the screen... Check its right in!
Sam Brockway
(look me up on youtube)
Posted on Oct 28, 2008
  • 61 Answers
You need only the ndsl touch screen , not the bottom lcd screen
Posted on Aug 22, 2008
Bottom internal touch screen cracked on ds lite-how do we get it repaired
Unless you are comfortable of taking it apart yourself and ordering the part online.
I'd suggest going here.
http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Mar 03, 2011 | Nintendo DS Lite Console
The touch screen isn't responding very well, sometimes it will react to a tap but mostly the screen is non responsive, the keys work ok when scrolling on a menu screen. any ideas?
first try to calibrate the touch screen.Take all games out turn on then go to the very small ds on the bottom touch screen. If you can't touch it move it with the cross down then hit a. Then select the option all the way to the right it looks like cross hairs that's the calibration screen fallow instructions. If that doesn't fix it it could be a broken screen or a loose ribbon.
Feb 24, 2010 | Nintendo DS Lite Console
When i turn on my new nintendo ds it says : Menu? and i cant do anything else.
may be the system firmware has crashed format the nintendo and u may get the problem solved
Sep 05, 2009 | Nintendo DS Lite Console
Screen does not react to the stylus when touching on found object
You could try calibrating the screen. To do this, you must go to the little DS in the center of the screen when you turn the DS on. Then touch the yellow square on the far right. It should give you instructions from that point on. Make sure that your stylus doesn't have a scratch on it! If it has a little nick down the middle, then your screen might not get a clear reading as to what you touched.
Hope it helps~
May 03, 2009 | Nintendo Mystery Case Files: MillionHeir...
Ds lite out of line (1cm out of where you touch on the screen)
Go to the main menu, then touch the mini DS in the bottom center of the screen. Touch the yellow icon farthest to the right. Follow the instructions from there on out. This is called calibrating your touch screen.
Hope it helps~
Jan 18, 2009 | Nintendo DS Lite Console
Nintendo ds bottom screen replacement
Yes I do have instructions to replace it (I replace them myself). Here's a web site that will give you detailed instructions.
http://site.powergamingparts.com/RepairNDS.html
Post if you have anymore questions.
Sep 11, 2008 | Nintendo DS Console
Nintendo DS behaving erratically-Screen malfunction????
Normally replacing the touch screen will fix these types of problems. Please note that there are two screens on the bottom and not just one. You have the touch screen and under that you have an LCD screen just like the LCD on the top. You will have to remove the touch screen from the LCD as it has double sided foam tape holding them together. Also, the small clip that holds the ribbon cable to the board is easily broken, so be careful with it. If you break it you will not be able to get the ribbon cable to stay in and the touch screen will no longer work and your DS will likely not stay on.
Mar 29, 2008 | Nintendo DS Console
Ds lite is broken
If you mean PHYSICALLY broken (as in cracked) then hit Ebay. Nintendo doesn't sell replacement parts. You will also nned a miniature Tri-Wing screwdriver to open the case.
Oct 31, 2007 | Nintendo DS Lite Console
Nintendo ds
need more info. try removing a screen protector you bought. those can make the touch screen less sensitive. also go into options and re-calibrate the touch screen.if all eles fails send it back to nintendo for repair
Aug 04, 2007 | Nintendo DS Console
Nintendo Planet Puzzle League NDS DS Tetris puzzle Game for DS Logo
298 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
