Question about Elna Quilter's Dream 6003Q
Error 4 and needle won't go down.... - Elna Quilter's Dream 6003Q
Needle won't remain threaded
make sure the thread has long thread tails of 4 to 6 inches long
and have the thread tails pulled behind the needle before starting
to sew.
Jan 04, 2013 | Michley Lil Sew Mechanical Sewing Machine
Brother XL5000 sewing machine won't do a 4 step button hole?
you didn't say if it's a mechanical or electronic sewing machine?
do you have a manual?
if you don't here is a link for one
http://www.manualslib.com/download/22168/Brother-Xl5000.html
does the machine have a buttonhole lever that you have to pull
down before you start the buttonhole?
Nov 15, 2012 | Brother Sewing Machines
The pressure foot won't go all the way down
take off side plate and loosen pressure ft screw . it should snap down. make sure the foot stays align wit the needle. u want the foot slot with needle in ctr.
Oct 20, 2012 | Juki TL-98Q
Clanking noise & won't sew
Are you sure you put the correct type of needle in? Normally, if you have any problem, cleaning and oiling will fix it. It sounds like you either didn't tighten the needle screw or you put the wrong type of needle in.
Jun 24, 2012 | Janome Sewing Machines
FS320 serger needles won't go up and down. New
if the machine is still under warrenty, take it back
if it's not under warrenty, take it to the place you bought it from & tell them
May 28, 2012 | Yamata Sewing Machines
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
How to change a needle
Remove screw at the bottom of the needle bar while holding needle carefully so it doesn't drop down into your sewing machine.
Push new needle all the way up until it won't go any farther and make sure the flat side is in back, the rounded side should be facing you.
Tighten screw securely.That's all there is to it!
Hope this helps.
Jimmy
Apr 01, 2012 | Sewing Machines
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Aug 02, 2011 | Singer 1507
I'm trying to sew my first buttonhole. It sews briefly then 6L comes on the computer and it won't complete the buttonhole What am I doing wrong?
Make sure you pull down the buttonhole lever from the underside of the machine (near where the needle threader is) If you don't do this, the machine will make a few stitches and then stop. with error 6L.
thanks for using fixya.
May 28, 2011 | Kenmore 19110 Computerized Sewing Machine
Sewing Machines Logo
18 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
