I have a Daytek DK-322 32 inch LCD hdtv television and the up and down channel butoons do not work on either the remote or the television itself. Everything else works fine and you can go to the different channels if you manually enter the digits. Any suggestions?
SparkGap
  • 363 Answers
SOURCE: tv channel problem
- I think you mean model P42. You can get the user manuals here:- http://www.vizio.com/support/downloads/ Note that the quickstart guide file is broken. You have to allow pop-ups, select the model and the manual will appear in a new window then you can save/print. Hope this helps! -
Posted on Oct 05, 2007
  • 87 Answers
SOURCE: Tv not changing channels.
This likely has a bad main board.
Posted on Oct 23, 2007
JULIANFIX
  • 975 Answers
SOURCE: iLO -3200 32 in. LCD
will NOT change channels , Direct manually on the TV?? or with the REMOTE CONTROL??? PLEASE KEEP ME ADVICE AJ
Posted on May 01, 2008
SOURCE: scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Posted on Jul 29, 2008
  • 1030 Answers
SOURCE: Convergence off on Digital Cable
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
HOW TO HOOK UP HDTV ATTENA TO DAYTEK 426F SO IT WILL ACCEPT CHANNELS
If your Daytek TV is equipped with a digital tuner, connect your HDTV antenna to the antenna input of the TV.
Feb 05, 2015 | Televison & Video
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
Aug 06, 2014 | Sceptre X322BV HD 32 inch Class Television...
Daytek troubleshooting
Check the aerial connections and try again.
Apr 29, 2014 | Vizio L32 32 in. LCD HDTV
I have a 37 inch HDTV LCD and the channel up and down buttons have stopped working. If you try to use these to change the channel the TV will mute. I thought it was the remote but I bought a universal...
Make sure the buttons are not jammed, meaning they push in and out freely.
There also may be a "Channel Lock" feature on the set in the main menu if you can get to it. If you have the manual, check troubleshooting section. If you still have an issue,
post a comment and I will help you further.
Sep 27, 2010 | Olevia Televison & Video
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Comcast Remote Control Code
It sounds like you either have a signal issue or a bad converter box, possibly both
Apr 23, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
