Question about Coleman Powermate Premium Plus 6250W Portable Generator
I can't get my Coleman Powermate electric generator model #PMA52500.01 to start. I'm cranking it, but nothing's happening. It shows the fuel is clear, fuel & oil levels are correct and the spark plugs look good. Per a PMA tech's suggestion, I've also sprayed WD40 down the throat of the carburetor - nothing.
  • 13 Answers
SOURCE: Powermate PM0535000-01 Manual
powermate went out of business , but this might help let me know http://www.powermate.com/contact.php
Posted on Sep 27, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
  • 243 Answers
SOURCE: coleman sport 1850 powermate generator, no fire to sparkplug
is there an oilprotection on the gen. disconnect the cable and try again
Posted on Feb 10, 2010
  • 905 Answers
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Posted on Jun 12, 2010
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Coleman powermate generator won't generate
Check rotor again and measure to see if you have DC voltage on the brushes while running. If no then suspect capacitor
Nov 11, 2012 | Coleman Powermate Powermate 5000W...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman Vantage7000 with electric start. I put a new battery and new battery cables and a new starter solenoid switch on it. I still get nothing and my next step is to replace the starting key...
IF IT IS A HONDA ,KEN . JUST UN PLUG THE LOW OIL CUTOUT SWITCH JUST TO BE ON THE SAFE SIDE MANY OF THEM GIVE TROUBLE.
IS IT TURNING OVER AND JUST NOT STARTING,OR DOES IT REFUSE TO CRANK? IF THAT IS THE CASE CHECKTHAT YOU HAVE A GOOD EARTH CONTACT.LET ME KNOW WHAT MODEL THE MOTOR IS "YOUDOIT"
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
