Question about Garden
Numatic wvd 1500p wet pump out vacuum what size hose do I need for the suction side
  • 43,501 Answers
A 38 mm or 1-1/2" hose will work for the suction side...
BB7 kit
heatman101
Posted on May 24, 2011
George pump strange noise
Check for blockages in all the filters and hoses, from your description it sounds like the pump is trying to go but can't
Jun 20, 2014 | Numatic GVE370 Canister Wet/Dry Vacuum
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
Apr 03, 2013 | Riccar 1500 Simplicity S24 And S20...
My henry wont pick up any dirt and how do i change the filter ...
The filter on a Henry does not need changing (unless torn or
damaged). It simply neeeds cleaning, either by vacuuming with
another machines or brushing clean. For maximum suction, air
must be able to flow through it. Next, change the bag. Finally
remove hoses and pipes etc and switch on, the suction that you can feel by putting your hand against his "nose", is the same suction that you should feel when pipes are back on.
If it is not, then you will have a blockage, usually in the flexi hose, but drop a coin through in order to establish where.
Feb 07, 2011 | Numatic Henry Bagged Canister Vacuum
I need a "floor tool" for a Numatic NVQ-380.
Any Janitorial supplier will have them, otherwise contact Numatic (www.numatic.com) who will supply at list price + p+p
Feb 06, 2011 | Numatic NVQ-380 Wet/Dry Vacuum
1672 BIGgreen Wet/Dry Vacuum: my bissell 1672 big green machine has stopped spra...
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in2_bing.gif the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
May 16, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
My pump runs but won't pump
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Nov 16, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Sep 10, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
George
Hi.
No the switch for the pump will work without main vacuum switched on.
Your problem could either be faulty pump switch or faulty pump,
You should be able to get spares relatively easy from any independant vacuum repair shop.
Dont try currys etc they wont have a clue what your talking about.
http://dysonmanuals.llc.nu/
Chris.
Feb 08, 2008 | Numatic GVE370 Canister Wet/Dry Vacuum
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
