Question about Astra Mega I Semi-Automatic
I bought a used Astra Mega 2 to replace one that I had. It turs out it wasn't as clean as they lead me to believe. Both heads seem to be lacking in water preasure and volume. The one head is so bad that when I went to program a shot it stoped trying after a minute. The steamers and americano work great. I am assuming I need to descale it but I am not sure how to go about doing that. I do not have a manual at this time.
  • 9 more comments
  • mousepadcoff May 23, 2011
    This is a commercial espresso machine. There isn't a "tank" there is a boiler and it has water plumbed straiget to it.
    I took the front plate off and noticed that what I think is the preasure reducer is all crusty.
    According to the plack on it the Model is a Mega 2
    I had been to that site already, but not to that specific page. I did check this page and the info there seems to be related to home machines not commercial. Also the link for descaling doesn't seem to work. Thanks for the info on the Astra's contact page I have already called them and asked for the manual. They are emailing it to me. It hasn't arrived yet.
    This is a commercial espresso machine not a home machine. The nearest repair person is over an hour away and they charge me $100 just to drive here. I am very good at repairing things so I believe that I can do this. I just need a little guidance. Thanks
    That is what I am asking, where would I pour it in? The whole thing is prety sealed up.
    While I was waiting for a reply I actually tried doing that. Not the solution.
    On my old machine (same modle) we would back flush the machine every night with cleaner. When we would do that the machine would have a large discarge of water from (what I will call the "presure reducer"). This machine just has a trickle. It seems that there just isn't any presure in the water flow. Even with the basket and filter removed, the flow from the head is so little that it takes almost a minute to get an ounce of water. Since the steam wands have enough preasure, I am assuming it was the heads that didn't have preasure.
    Thank you that would be great. let me know if you need an address
    mousepadcoffee@gmail.com
  • mousepadcoff May 24, 2011
    Thanks for the manual. We ended up taking the head appart and scrubbing in. I need to order a new group solenoid valve with coil. The one that was in there had so much crud it was frozen. Based on what we saw we could have cleaned it a thousand times and it still wouldn't have worked. But now I know how the head goes together. If you could ask your friend or if you happen to know. I need to replace the head gasket and I don't see an easy way to get the old one off.
    Thanks for your help
    gas_logs went out of their way to help. It turns out that we had to go a different route to get it fixed but they were helpful.
    Brigadier General:
  • 4,736 Answers
Actually, it's not that difficult to do. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (Enough to fill the tank(s). Fill the tank(s) with the solution and allow it to set overnight. The next morning, turn the unit ON and operate it as you normally would, until the water and steam responds as it should. Then empty the tank(s) of the solution and refill with Bottled Distilled Water. Operate the machine, until almost all the water has been used up. That will flush the unit of the previous solution. After that, descale as necessary, depending on how hard your water is.
Hope this helped you to solve the problem. Please let me know. Thanks.
Posted on May 23, 2011
  • 8 more comments
  • Rich Landrum May 23, 2011
    In that case, turn the waterline to the unit OFF and use the solution instead. It has to have a reservoir to allow the water to heat around the heating element.
    According to the specs on the Astra Mega I (either the automatic or semi automatic models) have a 7 liter boiler tank capacity. So, there should be place to pour in the solution, rather than use the hard piped waterline.
    The Mega II has a 12 liter boiler tank capacity.
    I understand your frustration. Look at where the waterline enters the tank. Above it, there should be a lid which you can open and pour the solution in. According to the specs on it, this is the access to the 12 liter tank. Of course, I'm assuming that you have a current model Astra, rather than one that's 8 years old. If that is the case, turn the waterline OFF and disconnect it from the unit. It probably was using a 3/8" line to fill the tank. If it's larger, so much the better. Then place a funnel in the hole and carefully fill the tank with the solution.
    Ok. New plan. I just got of the phone with a friend of mine that has a Astra II. Here's what you need to do. Remove the filter basket from the portafilter and replace with a blind filter.make sure the blind filter is pressed firmly into the protafilter. Put about 1/4 cup of the solution I mentioned earlier into the portafiilter. Instert the protafilter into the group head. With the blank filter nothing will dispense from the portafilter and te cleaning solution will escape through the relief valve, thereby cleaning the brewing mechanism. After the portafilter is placed on the machine, press the brew stop button and wait 10 seconds and press the brew stop button again. Repeat the process 4 more times. Do Not add more solution each time. After the 5th time, remove the portafilter and rise it out thoroughly. replace the portafilter on the machine. Repeat the procedure without any cleaning solution. When the water becomes clear, remove the blank filter and replace with a regular filter. If you have a 2 or 3 group machine, repeat the process with each group. Back flushing is an important maintenance set and should be done 3 times per week. Now that you have the solution to solving the problem, go to it!
    I think you may be correct. Never the less, it may really be clogged up, so keep trying. You've got nothing to lose. I sincerely hope , it's not a case, of you getting a unit that isn't what it was purported to be. My friend is going to scan the Owners Manual and send it to me. When I receive it, I'll forward it on to you. OK?
    Here's a long link. Try it. You'll have to copy and paste it into your web browser.
    https://docs.google.com/viewer?a=v&p...
    After sending the link, I found it won't work. Send me your email address, please.
    It's on it's way!
  • Rich Landrum May 24, 2011
    I'll see what I can do. Thanks for the 4-Thumbs up rating. I'm glad I could help you. In the meantime contact Astra Technical Service for that or any parts you need (877) 340-1800. They're good people.
  • 710 Answers
Hi mousepadcoff,
Can you give me the model of your Astro Mega II?
Thanks,
Handie Andie
  • 1 more comment
  • Handie Andie
    Handie Andie May 23, 2011
    As an afterthought, I don't think I need your model number.
    If you go to this webpage: >>>>http://www.partsguru.com/MaintenanceofEs... <<<< you can get all the information you need to maintain your machine.
    Copy and paste this address into your browser, then scan down the page to the espresso section and you'll find lots of information on descaling and cleaning in general.
    If you look down the left side of that webpage, you will see options for repairs, cleaning products, etc.
    Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
    Handie Andie
  • Handie Andie
    saw your comments when I posted. If you look about 1/3 of the way down the page I gave you, you'll see information for commercial espresso machines with manuals available to download.
    If this is not helpful, please let me know.
    Andie
  • Handie Andie
    The owner's manual for your machine is not readily available on the web. Here is Astra's contact page: >>>>http://www.astramfr.com/contact.html <<<<
    I'm sure they will make a manual available to you should you need one.
    Andie
My astra espresso mega 2 s boiler pressure is 0.
It is possible that the safety thermostat on the boiler has tripped. Reset safety thermostat and turn machine on. If reset is not tripped then it could be the element or the pressure stat are damaged.
Aug 01, 2014 | Astra Mega II Espresso Machine
I can't seem to undo Allen head screw which fixes sanding attachments to sanding unit
you might have to use an impact driver on this and also you might want to think that it is a left-hand thread, but I would recommend the impact driver to shock the bolt loose.
Jan 23, 2012 | Tools & Hardware - Others
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
Dec 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
I have an Astra Mega I single group espresso machine 110v. I seem to not be getting enough water through the portafilter and it is all clean.
Remove portafilter, shower and screw and run the head. Did you get a nice steady flow or a weak drip. If a weak drip then the solenoid or the metering jet on the head is blocked and needs to be cleaned. If you get a nice flow the adjust the grind on the coffee to coarser.
Jan 15, 2010 | Astoria Divina SAE-1 Espresso Machine
The steam wand and hot water valve work fine. Can't get any water out of the group head to make espresso. Pump sounds like it is working but no water comes out.
The coffee group is equiped with a jet and jet filer which is probaly blocked from dirt or scale. Need to be removed and clean up. Consider that the coffe solenoid valve and shower are clean from any dry coffee
Oct 31, 2009 | Astra Mega I Automatic
Can't get water out of the group head. Can hear the pump but no water and then error light comes on
The coffee group is equiped with a jet and jet filer which is probaly blocked from dirt or scale. Need to be removed and clean up. Consider that the coffe solenoid valve and shower are clean from any dry coffee Please remebr to vote for this answer thanks
Where to get it repaired?????
Try Mr. Espresso in Oakland, CA www.mrespresso.com. While they don't typically supply Astra, I believe they are familiar with the brand and can refer you to a technician if they can't service it themselves. Astra will also service their own machines, but you would probably have to ship it to their shop in LA.
Apr 17, 2009 | Astra Mega II Espresso Machine
Is the Astra Mega ll capable to pull a good shut with a 21g Basque?
Do it. It has the horsepower. You will probably just need to program the shots accordingly, and maybe get a deep basket for your portafilter.
Nov 06, 2008 | Astra Mega II Espresso Machine
Astra Mega IIC startup issues
Go ahead and keep the sensor probe connected. Open up the steam wands before turning the machine on the let the air bleed off as it fills. The element should not turn on if the water level is too low and the circuit is working properly. As for the groups pumping water, try hitting the Brew Stop buttons. If that doesn't work, something may be wired wrong, or your group solenoids may be stuck.
Sep 13, 2008 | Astra Mega II Espresso Machine
Astra Mega II <----Need help!
The left grouphead sounds like a different problem than the right group head. For the left grouphead, I would start by replacing the group electro-valve. With hard water, this can cause the valve to remain in the closed position even though the water pump is running.
For the right group head, I would want to see this happen. Usually, if the gaskets haven't been replaced in a while (if you are busy, your 'while' may be quicker than others), I would evaluate the condition of the rubber gasket. I would also look at whether you are tamping too much espresso grounds into the portafilter. This can cause a similar symptom as a bad gasket.
Apr 28, 2008 | Astra Mega II Espresso Machine
Astra Mega I Semi-Automatic Logo
424 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
