Question about Samsung Computers & Internet
My hardisk stop working any time - Samsung Computers & Internet
  • Samsung Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 23, 2011
Pc stops, dont see hardisk
This indicates the hard drive is bad, first remove the hardware and reseat it back in position, sometimes this will restart it, if there is no change time for a new hard drive.
May 01, 2012 | Fujitsu Siemens LifeBook E4010 Notebook
I have a D865perl MB some times for no reason my computer shuts down. It is a pain to restart, i have to turn it on and off atleast 20 times
That looks a hardisk failure.
Set the BiOS to "max. default operation", save upon exit. If you still got the same problem replace the HARDiSK.
Try to replace the hardisk and install your favorite OS.
Hope that helps!
Dec 02, 2011 | Intel D865PERL Motherboard
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
I have a " My Passport Essential Ultra-portable
Your portable harddisk is not working because the hardisk inside is bad or damage, try to change the hardisk inside. it also happen to me and when i chage the hardisk it works.
Thanks for using Fixya
Jun 01, 2011 | Western Digital My Passport Essential...
Hardisk tidak bisa terdeteksi oleh BIOS apa penyebabnya dan solusinya untuk memperbaiki ?
Hardisk tidak terdeteksi bisa di sebabkan oleh :
- Bad sektor
- Hardisk sudah lemah
- Cabel data rapuh/rusak
- Power Supply tidak mencukupi untuk keseluruhan Daya PC
langkah yg pertama :
- coba ganti cable data hardisk, dan periksa PIN Hardisk masih utuh atau tidak
- Ganti Power Supply yang Daya-nya lebih besar
- Scanning dengan hardisk lain dengan menggunakan Norton Disk Doctor untuk mengecek Bad Sektor
Mar 02, 2011 | Maxtor Hard Drive
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
Vista boot manager missing
Your hard drive is bad. It will keep crashing until you replace it.
Mar 25, 2009 | Dell Inspiron 1420 Notebook
Pc hardrive seems to be working more than usual
see if in your power options what you put for the amount of energy devoted to your hardisk
also see in your system about your harddisk setting
to assume the worst you have abnormal operation/a virus
and it would cause your system to use it harddisk more
but i don't think you should worry
harddisks are designed to work hard
hope to help
Dec 14, 2008 | Computers & Internet
Dell b130 restarting all the time
hi buddy!
1. Go to bios setup look if the computer see the hardisk and you setup the first boot priority is hardisk.if you encounter the same problem.
2. Maybe your operating system have corrupt then you try to reprogram the hardisk. if they same problem apear
3. Your hardisk have a problem you try to change a new one
bochard_20
May 16, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
