Question about Kitchen Ranges
My sunbed keeps tripping afta a few minutes and blows the 13amp fuse. the plugs is hot. what could be the problem?
noffie
  • 10 Answers
SOURCE: washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Posted on Apr 08, 2008
  • 83 Answers
SOURCE: Dryer trips the fuse box
I had this problem with our hoover tumble dryer, it might sound stupid but i changed the plug and it worked ever since, ours blew 5 fuses and tripped out the main fuse every time
hope this helps martin
Posted on Jan 24, 2009
bigg t
  • 640 Answers
SOURCE: Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Posted on Apr 11, 2009
  • 750 Answers
SOURCE: My 20 amp ignition fuse keeps blowing while
you may have an ignition wire with broken insulation causaing short to ground or a defective relay
Posted on Jun 29, 2009
  • 6 Answers
SOURCE: sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Posted on Aug 06, 2009
Ergoline sunbed, Sunbed lights keep going on and off while it's on cycle, it trips and the goes back on immediately does any one know what could be wrong?
Check your power supply rating of the circuit breaker that is feeding the outlet. The safety relay on the sunbed may be triggering because your circuit breaker won't allow enough current to flow to the sunbed. (The safety relay is far faster in actuating that the circuit breaker is to pop when drawing too much power.) Check the owner's manual and it will probably tell you you need a dedicated 16Amp circuit for the sunbed. These means the wiring has to be of proper diameter (gauge thickness) to handle the current. It shuts off and allows the sensor to cool down and then cuts on again... repeatedly. Also check the polarity of the outlet and ensure they match with the plug-in jack. (Often electrician's put the black wire and red wires on wrong poles inside the wall socket.. turn off the circuit breaker for the socket before changing them using an electrician's screwdriver with lamp inside the handle to assure the power is off first, please and make sure the green (ground) wire is connected also.)
Apr 24, 2015 | Health & Beauty
I have just brought a older style lie Down sunbed! My thing is the bottom section works fine ! But the top one as soon as I plug in the plug it trips the switch
Some of these units use more than 10amps [2400watts at 240volts 1100watts at 110volts] AND will cause the fuse to blow/or circuit breaker tripping every time on a normal wall outlet/circuit.
Best option is to get your local ELECTRICIAN to run a "DEDICATED" 15amp [or larger] CIRCUIT and wall outlet in the room where your Sun Bed is installed ...
The electrical amperage requirement for your unit should be found on the manufacturer's Compliance Plate [on your unit] ...
ALSO it is possible that there may be a FAULT in the top unit [sometimes caused by a damaged supply cable on the older type "CLAM-SHELL" units] ...
Probably best to have it CHECKED/TESTED by your local Electrician.
Sep 20, 2014 | Health & Beauty
Main fuse tripping
remove the cover from the heater spray with wd40, wipe dry, replace the cover and re-try
Dec 15, 2013 | Computers & Internet
The plug lead is getting very hot on my sunbed.why
can you tell me why the plug to my sunbed is red hot i darnt use is what is the problem
Mar 26, 2013 | Cars & Trucks
Awz8812 blows fuse
what 13 amp external fuse are you speaking about? if this is a power line fuse feeding the dryer then its way too small normally you use 2 30 amp fuses or a 30 amp tandem pole breaker to power the receptacle where the dryer plug plugs in
May 05, 2012 | Whirlpool GEW9250 Electric Dryer
We have an Hotpoint FDW70 Dishwasher that for some time has had an A10 fault which although stops the machine some times 70% of the time it does a full cycle. However it is now tripping out the electric at...
hi the fill valve triac is the plastic vlave that the inlet hose connects to you can get them for about £10 you reset the machine after replacing it by switching it on, pressing the power button leaving it off for about a minute then switching it back on, and the onboard diagnostic unit resets automatically.
Sep 25, 2009 | Dishwashers
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Washing machine
Apr 05, 2008 | Indesit W 123 Front Load Washer
Kitchen Ranges Logo
140 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
