Question about Ace Hardware Ace Green Turf Deluxe Broadcast Spreader
I have a Ace green turf spreader model 2030-AT part # 7204167. The wheels keep coming off and the parts (bushings & wheel cap) were lost in the yard. The spreader is less than one year old. I need these parts A.S.A.P.. Thanks, Jim Clower
What is the settting on the scotts accugreen spreader for ACE GREEN TURF SUNNY lawn sees None listed on the bag.
Sorry there are no spreader settings listed on the bag. Please give Scotts a call at 877-465-5160 and see if we have spreader settings available for you.
Sep 17, 2011 | Garden
Need part for scotts Speedy Green 2000. Support connecting storage basket to wheel drive shaft
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 877-465-5160 at your earliest convenience to check part availability. Hilary @Scotts
Aug 24, 2011 | Scotts Company Garden
The impeller drive wheel of my classic drop spreader won't turn unless you have a huge load on board. I wash it out every time I use it and dry it thoroughly. I've removed the wheels and tried WD...
Aug 24, 2011 | Scotts Company Scotts Turf Builder Classic...
I have a Scotts Turf Builder EdgeGuard Mini, and I'm using Ace turf builder (crabgrass preventer with fertilizer). What setting should I use???
I was just told by Scott's phone customer service (800-543-8873) that their TurfBuilder EdgeGuard mini can use the same settings as their "SpeedyGreen" broadcast spreader, if your fertilizer lists that one.
Apr 08, 2011 | Garden
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
Bushings
They don't have to be made by the same company that made the aerator. Take one bushing off and visit Ace or Home Depot. I would replace them all at the same time. But all you need to do is find the physical match and go from there.
Nov 02, 2009 | Brinly-Hardy Brinly Hardy Company 40" Tow...
Lost manual
I have a Scotts speedy green 3000. Got it $5 used. I just called Scotts, and they are sending me a manual. But, they told me how to calibrate it. First, you need to know if you have the same "version" as I do. Apparently they made the same model more than one way. I'm told I have a newer one. The way the Scotts rep differentiated was by the wheels. I have all black wheels with orange hubcaps. Older models have orange wheels. If you have the model I have, then do this to calibrate the spreader:
1. On the black slide that comes up when the handle is pulled to open the spreader and releasing product you will find a curved line about 1/2 and inch from the top.
2. Set the spreader to a setting of 2 on the handle.
3. When you pull the lever as if you were releasing product, the indented black line should line up with the curved part of the green hopper at the top of the opening.
4. If it does not align, then you need to adjust the cable that run from the handle down to the hopper door. This is done using pliers of wrench by turning the square nut at the bottom of the cable. It's trial and error at this point.
Mine was off by 30%.
Good luck
Apr 19, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Fix the distribution propeller on a broadcast lawn spreader
back yard fix
use the right size nail
use the right size split pin
use the right size bolt
Sep 10, 2017 | Garden
Ace Hardware Ace Green Turf Deluxe Broadcast Spreader Logo
277 people viewed this question
Top Ace Hardware Garden Experts
Ed Hauk
Ed Hauk
Level 1 Expert
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you an Ace Hardware Garden Expert? Answer questions, earn points and help others
