The inside wirless anthena is off. where is the on located ?
    Sergeant:
    Novelist:
  • 159 Answers
This depends on the Operating system you have and the hardware you are using. For example, a linksys wireless adapter can be turned on and off through the Windows control panel. If you are running Linux, you will have to find the package that controls the adapter and make sure it is active. I am not sure how it works with a Mac, but there should be an option for it located near where the "network connections" are controlled. Windows XP has a listing for "Wireless Network Setup Wizard" which will help you through the connection.
There could also be an issue with your router. This is the piece of hardware that connects your home network (your PC's and laptops) to the internet. Each router works differently, but there are similarities. If you have tried turning the wireless on through your operating system and it is still not working, or your computer tells you that there are no networks in range, your router's wireless might be turned off. To fix this, get your router's user's manual and find the IP address. Go to your web browser and type the IP address of your router into the address bar -- this will give you what looks like a web page (it's actually the interface for your router). Look at all of the wireless options you can find to make sure it is turned on at the router, then try your network setup on your computer again.
If neither of these solutions corrects the issue, go to the web site for your wireless adapter's manufacturer and search for the model number or serial number of your adapter. Lots of times there are FAQ's that will help you resolve the issue. If there is still no help, try the manufacturer's site for your router .. their FAQ's may have a solution.
Most likely this problem is with your software not being turned on, not the hardware, and the above solutions should help. If nothing else is working, then you might have a hardware issue. Make sure the wireless adapter is plugged in to a working socket (if it's USB, try another port, if it's inside your computer, you might want to seek the assistance of a professional repair shop).
Posted on May 23, 2011
    Sergeant:
  • 167 Answers
Go to start right click my network places then properties then right click wireless network then enable
Soniq tv problems
Check its input connections, and input selections. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.
May 11, 2013 | Televison & Video
Internet light is blinking fast and wireless network is down
reset your anthena and make sure there is not any wireless signal interfering device near to ur wirless router.. make sure u had enable the wireless option in your router
Dec 03, 2011 | Linksys Wireless-G WRT54G Router
I have no network on my lycamobile . why?
one possible reason is the network server of your telephone provider. Or their are no signal at all in which the area is either isolated or no base anthena of the phone provider. One reason also is the phone itself maybe you have mistakenly configure that network channel of your phone. Try to check it first. Thanks
Sep 23, 2011 | Cell Phones
I am having some problem with antenna in some regions in city while other cell phone work normally....
probably your cell phone anthena dosen't have quad band or tri band and the other cell phone has
Feb 17, 2011 | Cell Phones
Why do I have an 'E' on the side of the signal bar instead of the anthena icon? and how do I fix it?
I think the E refers to what speed data network you can connect to.
My phone shows an E or 3G symbol depending on where I am.
Mar 23, 2010 | LG Neon GT365 Cell Phone
Wirless lan drivers for win7
download the driver on the asus website, just locate your model there and download
Feb 15, 2010 | ASUS P5AD2-E Premium Motherboard
Nissan Pathfinder 2004 radio anthena
try checking the fuse, if the fuse is ok remove the radio and see if the blue wire is hooked up, if it is then you may have a broken cable in the mast, when you turn the radio on does it make any noise where the ant ene is?
Jun 20, 2009 | 2004 Nissan Pathfinder
Wirless signal problem
Make sure there is no interference, such as microwaves or cell phones that operate at 2.4ghz. Do you have many thick inside walls between your router and your computer? You could try a signal boosting antenna to attach to your router.
Apr 22, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
I NEED CODES TO MY WIRLESS CEILING FAN REMOTE
What codes? There are 4 dip switches (see DIP switch wikipedia) inside the remote control and 4 inside the sensor that is inside the fan. They have to be in the same position. If you don't feel like messing with the one inside the fan, keep changing the ones inside the remote. U= Up, D = Down
U-U-U-U, U-U-U-D, U-U-D-U, U-D-U-U, D-U-U-U, U-U-D-D, U-D-U-D, ... D-D-D-D (*There are 16 possible arrangements*) On e of these arrangements will work (has to work) if the remote components are not damaged.
Nov 12, 2008 | Universal Remote Control Hampton Bay...
My wirless is not working
The wireless switch is located just behind and to the left of the wireless LED. The wireless LED is located on the left of the bottom half of your laptop looking from the front between the battery, power and harddrive LED's and the audio jack sockets.
Aug 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
David Payne
David Payne
