Question about Sony Playstation 3 (PS3) Console
I have lines runnng up my screen works fine when wires unpluged
  • 127 Answers
Its on its way out¬!!!!!! almost dad e.g. ylod!!! visit my website xbox360repairspro.webs for more help
Posted on May 29, 2011
What does blinking pf mean
This means 'Power 'Failure'.
This could be from the circuit breaker being tripped and then was reset, wall outlet issue, or possibly if the cord was replaced then the screws conecting the wires to dryer may not be tight. Make sure dryer in unplugged before checking connections.
Some homes have an energy management system where higher energy use appliances are given a priorty so they all cannot run at same time so keeps your electric bill lower.
For example, the water heater and a/c system would be wired to override the dryer so if both these were runnng and then you turned on the dryer, the control unit would shut power down to dryer within a short time.
Hope this helps.
Jun 27, 2014 | Kenmore Elite HE4 Electric Dryer
Stuck in hibernation mode only get black screen
Probably if you can hear the hdd runnng and lights are switching on and off then, the display cable is undocked. Try openning the machine side if not, then the screen side cable.
Mar 20, 2013 | Computers & Internet
Hooked up new 4 wire fan 2 condensor with a new 2 cap fan runs fine but no compresor?installed as was told with nothing runnng 2 the new cap but the brown wires but compresor isnt kicking on
The compressor could be bad there is two ways to tell with an ohm meter check each lead off the compressor and to ground for continunity or a megometer . You can always try a hard start kit. It is a super capicator that multiplies starting voltage. Have you checked all connections? There might be a low\ high Pressure switch in the referigent lines if that is bad it won't allow the unit to start. Also is it a heat pump or straight a/c the heat pumps have circut control boards in the unit that control everything
Aug 07, 2011 | Goodman CLQ36AR49 Air Conditioner
My Kitchenaid model KURD25SHBL0 dishwasher is not draining. Drain line is clear, wash cycle runs fine, and there is no obstruction to overfill sensor. Can hear pump runnng during drain cycle but no...
Usually the wiring won't affect the direction of the pump turn. It is more likely that the fins on the drain pump empellar are damaged.
May 30, 2011 | Dishwashers
Truck runnng rough
Sorry I don't have a solution for this problem yet, but I think I am having a similar problem and I am currently working on tracking down the problem. Just wondering if you have more details for your problem? Were you driving it when the problem occured? And have you had any recent wiring issues, dead battery or anything of the sort?
Feb 14, 2011 | 1996 Chevrolet Suburban
I use a acer aspire 5810TZ and have a vertical line runnng through my screen how do i fix this problem
Well, if this is the same problem I'm having with my 5810T, then the settings have nothing to do with the vertical lines. There are vertical lines on my acer because the framing of the screen isn't thick enough. Thus, the lines are caused by the lack of sturdiness. Changing settings does nothing. However, pushing on the frame on the bottom of the screen adds more vertical lines. Releasing gets rid of some of them. Tapping also helps, but the problem only gets worse with time.
Nov 09, 2009 | Compaq Presario M2000 Notebook
My samsung hdtv has horizontal lines running across the top third of the screen. What is this and how much will it cost to fix??
screen is going down need new one or give this ago it might work mark on side of tv were about lines are this will help locate witch strip wire that is faulty
WARNING HIGH VOLTAGE EVEN WHEN UNPLUGED !!
Unplug tv and take back off you will see on the sides of the screen inverter boards with firley wide ( Brown strip wire ) going into them and were your lines are on screen lift or flickup the locking clip on that strip clean strip and board conection
RECONECT IS REVRES make sure strip wire is located corect and locked if worked will save you money if not you will need screen
Nov 07, 2009 | Samsung TXT3093 30 in. Television
"handset. No line"
Unplugging the phone will only fix the problem temporary!
Can anyone fix it for good? I am fed up of unplugging it every day.
No line... no line no line!
Stupid phone!
Mar 24, 2008 | Vtech Cordless 6041 Phone
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
