Question about Toshiba e-STUDIO 28 Printer
My Toshiba e-studio 28 stopped running dead in its tracks and threw the breaker in my main switch box. I unplugged the copier, reset the breaker, plugged the copier back in and attempted to start it again. It immediately kicked the breaker again. the repair man was able to start it with the fuser disconnected, so he installed a new fuser. When he started the copier with the new fuser, it immediately again kicked the breaker. Do you have any suggestions as to what might be the problem and how to fix it? thanks, Walter Foster
  • 670 Answers
How many amperes/watts can the breaker hold? try putting a breaker that is capable of handling higher wattage or ampere and check if it would do the same thing.
I'm not sure what happened to your printer but putting a breaker that can hold more electric current will definitely help out.
Hope this helps!
Posted on May 23, 2011
How to reset Toshiba e-Studio 161 Copier Copier with "error code H4"
Step 1:-
Press
"C" key AUTO/TEXT/PHOTO key
"C" key AUTO/TEXT/PHOTO Key
(Note:Perform the first two key strokes quickly )
Machine display should stop blinking
Now press 14 and press start button.
Switch off and on to check
Feb 27, 2016 | Toshiba Office Equipment & Supplies
It doesnot work appear "call for service" how can I reset it.
Toshiba STUDIO 232 User Functions Manual
download this manual or go to page 81 of the manual.
the link below is contact support from Toshiba Support
http://gethuman.com/phone-number/Toshiba-com
800-457-7777
Average Wait: 28 mins - 24 hours, 7 days
Jul 01, 2015 | Toshiba E-Studio 232 Copier
Toshiba E-Studio 356 Copier error C440
can do [1] cancel 0+5 together touch and main switch on 400 touch print switch touch 0 touch inter-up touch and do off on [2] change thermostat [3]heater bod chang
Aug 17, 2014 | Toshiba E-Studio 356 Multifunction Copier
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
My relay switch keeps tripping and resetting when the key is on, resulting in a draw on the battery and funny running until the battery is dead. I replaced the key ignition but the problem is still there.
You have a dead short somewhere in your wiring. You need to track down the short to resolve this issue. Start by determining which breaker keeps tripping. If it is the main breaker the fault will most likely be in the wires coming from the ignition switch the rest of the breakers. If it is the breaker with gray wire from the ignition switch it will be in the ignition/starting wiring. If it is the breaker that is connected to the gray wire from the ignition switch through a brass bridge bar the short will be found in the horn, turn signal, warning lights, or brake light circuits. If it is the breaker that is connected to the green wire ignition switch it will be in the running lights circuit.
Jun 15, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
My toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Jamming
I have a couple of Toshiba machines with finishers in my office. I don't know if they use the same one as the 28 uses.
Is the rollers where it is getting stuck at have a dark cover with the number 1 on th handle?
Aug 14, 2008 | Toshiba e-STUDIO 28 Printer
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Aug 23, 2007 | Toshiba e-Studio 350 Copier
Toshiba e-STUDIO 28 Printer Logo
54 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
