Question about Hayward SAND FILTER, PRO SERIES
My filter has nuts and bolts attaching top to bottom. I have removed all of them. Does the top lift up or does it screw off?
    President:
  • Hayward Master
  • 1,378 Answers
Holding the tank together? I assume you have an S160, S200 or S240. If so the two halves just lift appart although they usually need a good pull or pry to break the air vacuum in them. If not, please verify the model number and if you mean the tank itself or the valve on top or off the side of the unit.
John
Posted on May 24, 2011
L200 Saturn 2002. Where is the blower fan located for the heat and ac?
It's in the engine compartment. See removal instructions below from autozone.com.
  1. Select the following settings:
    Turn the ignition ON Select Recirc in the OFF setting Turn the ignition OFF
  2. Disconnect the negative battery cable.
  3. Remove the wiper arm assemblies.
    CAUTION A sharp edge is revealed once the weatherstrip is removed.
  4. Remove the weatherstrip at rear of the engine compartment.
  5. Remove the cowl retaining nuts.
jturcotte_564.gif Fig. Remove the cowl screen assembly
  1. Remove the cowl screen assembly.
  2. Rotate the locking tabs outward to release the filter assembly.
  3. Remove the filter by lifting straight up.
jturcotte_567.gif Fig. Remove the wiper module retaining bolts
  1. Remove the wiper module retaining bolts.
  2. Reposition the wiper module to the right.
  3. Remove the filter housing attachment bolts.
  4. Remove the filter housing.
  5. Remove the blower motor housing:
  6. Remove the blower motor housing screws
Fig. Release the locking tabs and remove the fan housing
  1. Release the locking tabs and remove the fan housing
  2. Disconnect the blower motor electrical connector.
  3. Squeeze the bottom of the connector and pull downward.
  4. Remove the blower motor assembly by lifting straight out.
Dec 20, 2010 | 2002 Saturn L-Series
How do I replace the heating fan on my 2000 Kia sportage
Blower Motor
Removal & Installation
To Remove:
  1. Evacuate and recover air conditioning refrigerant.
  2. Remove battery.
  3. Disconnect and cap A/C lines at evaporator tubes.
  4. Remove blower motor assembly drain.
  5. Remove glove box.
  6. Remove 5 screws and right hand instrument panel lower trim panel.
  7. Remove screw that attaches upper center console to gain access to left
    instrument panel lower support.
  8. Remove left and right bolt and remove instrument panel lower support.
  9. Detach control cable from inlet duct.
  10. Disconnect blower motor electrical connector.
  11. Pull carpet back and remove hole cover plate.
  12. Remove 2 bolts at top of blower motor assembly.
  13. Remove 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  14. Remove blower motor assembly.
To Install:
  1. Install blower motor assembly.
  2. Install 2 bolts at top of blower motor assembly.
  3. Install 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  4. Install hole cover plate and replace carpet.
  5. Connect blower motor electrical connector.
  6. Install instrument panel lower support and install left and right bolts.
  7. Install right hand instrument panel lower trim panel and 5 screws.
  8. Install glove box.
  9. Install blower motor assembly drain hose.
  10. Connect evaporator lines at bulkhead.
  11. Evacuate and charge air conditioning refrigerant.
  12. Install battery.
Oct 29, 2010 | 2000 Kia Sportage
How to remove and install a new heater blower motor 2000 Saturn
  6. Remove the cowl screen assembly.
  7. Rotate the locking tabs outward to release the filter assembly.
  8. Remove the filter by lifting straight up.
  9. Remove the wiper module retaining bolts.
  10. Reposition the wiper module to the right.
  11. Remove the filter housing attachment bolts.
  12. Remove the filter housing.
  13. Remove the blower motor housing:
  14. Remove the blower motor housing screws
  15. Release the locking tabs and remove the fan housing
  16. Disconnect the blower motor electrical connector.
  17. Squeeze the bottom of the connector and pull downward.
  18. Remove the blower motor assembly by lifting straight out.
To install:
NOTE The fan motor assembly rib must be located into the channel in the module housing.
  1. Install the blower motor assembly into the module housing.
  2. Connect the blower motor electrical connector.
    NOTE The housing rib must fit into the slot in the HVAC module case.
  3. Install the blower motor housing. Snap the left and right clip into place
  4. Tighten the fan housing to blower motor housing screws to 9 inch lbs.(1 Nm).
    NOTE A new filter housing seal must be used whenever the filter housing is removed to prevent water from leaking into module.
  5. Remove the filter housing seal using a small flat-blade screwdriver.
  6. Install a new filter housing seal.
  7. Install the filter housing.
  8. Install the filter housing screws, and tighten the screws to 31 inch lbs.(3.5 Nm).
  9. Position the wiper module.
  10. Install the wiper module bolts, and tighten the bolts to 44 inch lbs.(5 Nm).
  11. Install the passenger compartment air filter. Notice the air flow direction indicator printed on side of the filter.
  12. Rotate the locking tabs on the filter housing inward to secure the air filter in place.
  13. Install the cowl screen.
  14. Install the cowl screen nuts, and tighten the nuts to 9 inch lbs.(1 Nm).
  15. Close filter access door.
  16. Install the weatherstrip at rear of the engine compartment.
  17. Install the wiper arm assemblies.
  18. Connect the negative battery cable.
  1. Disconnect the blower motor electrical connector.
  2. Remove the lower blower motor cover retaining screws.
    Fig. Remove the lower blower motor cover
  3. Remove the lower blower motor cover.
  4. Remove the blower motor nuts.
    NOTE Cut through the case as straight as possible because the motor cup must be replaced.
  5. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
  6. Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
  7. Release the blower motor retaining tab and remove the motor from the cup.
To install:
  1. Install the blower motor into the motor cup that was cut out of the lower case.
    Fig. Install the blower motor (1) into the motor cup (2) that was cut out of the lower case
  2. Install the blower motor nuts, and tighten the nuts to 21 inch lbs.(2.4 Nm).
  3. Attach the service ring to the motor cup with the screws included in the kit, and tighten the screws to 15 inch lbs.(1.8 Nm).
  4. Install the blower motor and service ring into the HVAC module using the screws included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle, and tighten the screws to 15 inch lbs.(1.8 Nm).
  5. Install the lower blower motor cover.
  6. Install the lower blower motor cover retaining screws, and tighten the screws to 15 inch lbs.(1.8 Nm).
  7. Connect the blower motor electrical connector.
Hope this helps (remember to rate and comment this).
Oct 04, 2010 | 2000 Saturn Ls 4dr Sedan
ALTERNATOR REPLACEMENT
Assuming this is a XG 350, the process is lengthly.
1. Remove the RH radiator cooling fan (two 10mm bolts at the top & wiring harness connector to it).
2. Lift vehicle to remove the Right Front wheel (then remove 4 10mm bolts securing the plastic splash shield & remove it)
3. Loosen the 14mm nut on the alternator belt tensioner pully
4. Loosen the tension on the belt by rotating (counter-clockwise) the 14mm bolt at the bottom of the idler pully and remove the belt.
5. remove the pully & the idler pully (three 12 mm bolts)
6. Loosen the 14mm nuts at the top and bottom mounting points of the alternator.
7. Using a floor jack (or vehicle lift), support the engine using a jack-stand & 2x4 piece of wood under the oil pan.
8. This is tricky - lift the engine 'SLIGHTLY' to take pressure off the front engine mount - loosen the 17 mm nut on top of the mount itself and observe engine movement. If the engine moves upward 'slightly' remove the 17mm nut - if not, raise the engine slight more until you see the mounting bracket rise off the mount.
9. Remove the remaining 17mm nut (deep well socket), and two 17mm bolts and remove the engine mount bracket.
10. Here's another tricky step. Some 350's bottom Alternator bolt bores are 'SLOTTED'... some are NOT. You'll need to determine wether you'll need to REMOVE the lower bolt, or just loosen the mounting sleeve at the bottom bolt. If it's 'sleeved', I use an air hammer to loosen the sleeve. If it's not slotted, I remove the lower bolt (it's the only way to remove the alternator and pry it off).
11. At the top is an "L" bracket which uses two 12mm bolts to attach it to the engine (head). One of the two 12mm bolts is difficult to get to -- do your best to remove it because the battery cable to the alternator is in the way.
12. Disconnect the alternator wiring (battery cable & regulator harness connector)
13. Lift the engine as high as it will go & pry the alternator off its lower mounting.
14. manuver the alternator upward taking care not to damage the radiator.
15. Installation is in reverse order.
NOTE: If your XG's lower mounting point was slotted, your task is easy. If it isn't, your task now becomes more difficult as you must align the new alternator to facillitate re-insertion of the lower bolt.
PS If not slotted, I use a telliscoping magnet to help re-insert the lower bolt.
Aug 09, 2010 | 2004 Hyundai XG350
I cant find the battery in my grand prix se 1994 pontiac
1. Loosen the four screws that hold down the top of the air filter box. 2. Loosen the clamp that attaches the air filter box to the intake hose. 3. Disconnect the air sensor connector from the top of the air filter box. Note: Secure the connector wire, it tends to drop down and more than once I have had to remove the air filter box to retrieve it. 4. Remove the top part of the air filter box. You may need to twist it to get it to release from the rubber air inlet Hose.
5. Remove the two bolts holding the bottom of the air filter box. 6. Remove the bottom part of the air filter box.
7. Disconnect the negative then the positive battery cables.
8. Remove the three bolts that hold the brace that goes over the Windshield washer tank. 9. Remove the brace.
10. Remove the Battery hold down clamp at the base of the battery.
11. Remove the two nuts that hold the fuse box to the fender well. 12. Remove the two fasteners from the front of the widshield washer tank. 13. Rotate the windshield washer tank away from the battery. You may need to move the tank and lift the fuse box to get the tank clear of the battery. 14 Remove the battery.
To Install reverse the steps.
Time: 5 to 10 Minutes
Jul 16, 2010 | 1994 Pontiac Grand Prix
How to remove headlight assembly on 02 tundra
Once you have removed the screw on top, remove two visible lower nuts at bottom. You will also need to gently pry the plastic snap attachment that looks like a screw on top that holds turn signal in place. This is done by gently prying upward. These are plastic and sometimes brake. Your local parts store such as Pep boys should carry this item if you need to replace.
At this point the turn signal is free to be removed and will grant you access to the lower hold down nut that holds the headlight bottom. The turn signal can be stubborn to remove. I found that once I freed the top I could pull forward to free bottom. Keep in mind the turn signal removes by pulling straight forward from the vehicle. Pulling in any other direction may cause damage.
Oct 20, 2009 | 2002 Toyota Tundra
How do i take the heater core out of my 81 f150
Disconnect battery ground cable.
Disconnect cable from temperature blend door and the mounting bracket from top of heater assembly.
Disconnect blower motor and resistor electrical connectors.
Disconnect and plug hoses from heater core.
Working under instrument panel, remove 2 nuts on 1980---81 models, or 3 nuts on 1982---87 models, attaching left side of heater assembly and right side of plenum to dash.
On 1980---81 models, remove screw attaching top center of heater assembly to dash. On all models, remove 2 screws attaching right side of heater assembly to dash, then lift heater assembly out of vehicle.
Remove heater housing plate attaching screws, nut and bolt and the plate. On 1980---82 models, remove 3 heater core frame attaching screws and the frame. On all models, slide heater core and seal out of heater assembly.
Reverse procedure to install. Good Luck and hope this helps
May 02, 2009 | 1981 Ford F 150
Need instructions on replacing filter head on a haywad de filter ec75a
Remove the nuts and bolts around the head of the filter. The top then seperates from the bottom. if the top of the tank is broke you need to remove the black cover and continue disassembly.
Remove the grip from the handle. Usually a squeeze clip to slide grip off. Slide black cover over handle.
Remove bolt holding handle on to bump shaft, might be addtional drift pin that needs to be removed. Tap out with a drift punch.
Once these are removed the bump shaft will be attached to the top and bottom plates with the main gasket still attached. The filter Head is now free to be replaced.
Apr 24, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Screw rusted; cannot remove
ok for one, once you remove the screw hopefully you havent damaged the armature, which is the most important part,,,,1. get vice grips 2. try to get something to lock the sides down, ......question first, do you know if it works, if it does why are you taking the screw off, also if it doesnt its unfortunately probaly not worth fixing, if you need parts off of it just crush the side open..... if you come across another unit that has a screw loose, use silicon on the bolt and screw it will help keep it from rusting...
Jan 25, 2008 | Rainbow 75th Anniversary Canister Vacuum
Hayward SAND FILTER, PRO SERIES Logo
78 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
