Question about Garden
The flame keeps going out when I light the Butane soldering iron. I have read the instructions. It lights, but when I release the top part (iron) and it slides back it goes out. Fuel is good. It works great without the soldering tip attached. What's going on?
bestdarngood
  • 3037 Answers
SOURCE: Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Posted on Mar 29, 2008
  • 2318 Answers
It looks like the cord has a loose connection and will need to be replace.
meBNme
  • 334 Answers
SOURCE: bosch aquastar 125b ng
Replace the thermocouple.
Thats the flame sensor.
If the gas valve is not sensing flame it will not stay lit.
T-couple's are about 9 bucks.
Posted on Dec 06, 2008
  • 508 Answers
SOURCE: Can't change tip on soldering iron
use small vise grips on edge of screw!
Posted on Jun 24, 2009
  • 127 Answers
SOURCE: It is a cordless soldering
I am familiar with many models of butane powered soldering irons made by Benzomatic. Please let me know what your model and question is.
Posted on Jan 04, 2011
Why does the curling iron not stay on and get hot
You have lost a soldered connection on the Circuit Board and it is time to throw it away for your own safety
Jul 17, 2014 | Thermacell Conair Cordless Curls Butane...
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Mar 24, 2011 | Milwaukee Tool Weller Pyropen Jr Cordless...
Weller PSI-100K doesn't ignite. I have taken off the tips and checked. There is a spark and I can ignite it minus the tip. It only then stays ignited if I keep pressure on the ignition switch. Once that is...
I have the same soldering iron and have found for this problem, the replaceable tip has worn out.
All you need to do is buy a replaceable tip of your choice. The tips are a consumable part that wears out.
Jan 09, 2011 | Weller Portasol Pro Cordless Butane...
Bought mini butane soldering iron today filled with butane and used it. It was getting low so i put more butane in it and now i can light it. please help
When you fill the soldering iron with butane you must have it turned so the butane can is held upside down. Liquid butane must be able to flow into the iron. It's most likely that you held it upright and even though gas butane would have flowed in it would not be enough to light it. Only fill it outdoors.
Oct 05, 2010 | Radio Shack Welding Tools
My Pyropen WPA2 will not ignite I have changed the gas ,it has Butane UN1950 in now and is Half full
Does it spark?
Does the butane come out?
How old is it, and how much has it been used?
Did you put cheap butane in it at some point?
Sep 10, 2010 | Weller WPA2 Pyropen Professional Self...
Old Victorian Light fixture needs to be repaired. I think soldering the broken parts together would work, but I've never soldered brass parts (only simple electronic motherboards). Anyone out there that...
to solder brass u just use regular solid solder with a tin of acid flux, but u must use a Small butane fueled pin torch or a large high temperature solder iron to do the heating (this really depends on the size of the material being soldered), the brass must be clean and bright, use steel wool for this these small torches are available from any hardware store, they fuel up with butane cartridges used for refilling cigarette lighters
Jan 18, 2010 | Welding Tools
Brand new Weller Mcm Magna Lite butane torch does not light
If this is an itty ***** torch, The fuel is very sensitive . Too much screws up the air fuel ratio so try turning it way down and after the tip has heated up, you can increase your flame. Good Luck, Ned
Aug 27, 2009 | Weller Mcm Magna Lite Butane Table To
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
