Question about Mantis 2-Cycle Tiller
Can not find my manual for the mantis tiller..forgot hot to start it up for the first time
    Problem Solver:
  • 17 Answers
You should be able to go to the Mantis web site and download the owners manual. To start, make sure the switch in turned on, push the fuel primer bulb several times (until you feel resistance), pull the choke out all the way and pull the starter rope until it fires. Then, push the choke half way in and it should start. Let it run a 30 seconds to 1 minute and then push the choke all the way in. Be sure you are using the currect fuel/oil mixture with fresh gas and oil. If you have not done so already clean the air filter and replace the spark plug at the recommended interval.
Posted on May 24, 2011
Starting manual for mantis
all of the mantis tiller manuals can be found here:
http://mantis.com/mantis-owners-manuals.asp
just pick out the appropriate one and away you go.
as far as starting it goes, make sure the switch is set to "I" and not "O" (top handle.) be sure you have gas in it, pull out the choke knob (front of the tiller) and depress the bubble once. pull the engine cord until the machine tries to start, then push in the choke and pull again - the engine should start within a couple of pulls. let it warm up before you try to do any tilling, and you're good to go!
Sep 12, 2012 | Mantis Gas Mini Tillercultivator 2cycle...
I need an owner's manual for Mantis mini tiller
Try www.mantis.com. You should be able to find the manual for download or request one from Mantis.
May 22, 2011 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
We purchased a mantis 2 cycle garden tiller new and have only used it 3 times. it has only been used maybe 1 hour total and now it wont start at all. what can we do to get it to start?
Empty mantis fuel tank. Remove and check spark plug. Replace with Champion CJ8Y or NGK BPM7Y if necessary. Gap is .6mm - .7mm or .024" - .028". Prepare fresh fuel/oil mixture. Add fresh fuel to tank along with 2 ounces of 100% acetone (available at walmart) - this will remove deposits inside of mantis from sitting for prolonged periods. Try to start several times. If unsuccessful let mantis sit for a while. Do this several times if necessary. Eventually it will try to start. If it will not remain started then you are successful in completing the previous section. Next you need to watch this video and do what it says. It is actually quite simple.
http://www.alamia.us/mantis_parts_s/148.htm
Feb 04, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a mantis 2 cycle tiller. it starts and runs for a minute then shuts off.
do a fuel system overhaul...but always w a 2 stroke pull the muffler and inspect the piston and cylinder if its not scored and you feel good compresion most likley its your fuel system. if it is scored it gets metal to metal and the hot metals expand.
Jun 22, 2010 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I forgot how to start my mantis.
close the choke , pump primer bumb 3 or 4 times pull rope with the switch turned off then turn it on and pull rope again.
Apr 25, 2010 | Mantis 2-Cycle Tiller
I had my 2 cycle tiller at a shop and he told me
Mantis Product Owners Information
spacer.gif arrow_red.gif Submit your Question spacer.gif Please Select a Category Below arrow_green.gif Mantis Tiller/Cultivator Gas Tiller FAQ (12) arrow_green.gif Mantis SprayPartner and SprayMate FAQ (7) arrow_green.gif Mantis Blower/Shredder/Vac Service FAQ (3) arrow_green.gif Mantis ComposT-Twin FAQ (10) arrow_green.gif Mantis Edger FAQ (7) PARTS
If you need parts, or wish to return a product, please call our Customer Service Department at 1.800.366.6268
Hours are Monday through Friday 8:00 AM - 5:30 PM Eastern time.
Jun 07, 2009 | Mantis 2-Cycle Tiller
Trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
May 16, 2009 | Mantis Tiller
Mantis 2-Cycle Tiller Logo
231 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
