Need to install a seagate 7200.9 hard drive from a dell computer into another computer.
  • 2 more comments
  • amryform Aug 15, 2008
    The Dell Sagate HD Barracuda has a data cable for SATA BUT the power cable is a15 pin flat keyed cable rather than the standard power connector on the other computer. I was wondering if it is possible to use this HD in another computer to access info on it as the PSU on the Dell HAS FAILED?
  • amryform Aug 16, 2008
    Hi Steve,
    The Dell Seagate HD Barracuda has a data cable for SATA BUT the power cable is a15 pin flat keyed cable rather than the standard 5 pin power connector on the other computer. I was wondering if it is possible to use this HD in the other computer to access info on it as the PSU on the Dell HAS FAILED.
    Fred
  • cspgmg
    cspgmg May 11, 2010
    Is it SCSI or IDE drive, if SCSI, do you have a SCSI Card installed in your Dell PC.
  • Steve Si
    Steve Si May 11, 2010
    What is the problem?
    Sergeant:
  • 395 Answers
I don't quite understand what you are asking?
If you have a SATA drive then you need to connect it to a computer that has a SATA interface. You obviously also need to power it from that computer.
Since you haven't told me what the problem is or what the 'other' computer is, I can't really give you much more info.
Assuming you have a SATA interface on the 'other computer' and you have a suitable power cable adaptor from 5-pin to 15-pin (which you may be able to take off of the Dell) then of course you can connect the drive.
Are you are asking, is it possible to boot the other computer using this drive - answer unlikely.
Are you asking is it possible to connect this drive as a 2nd hard disk onto the 'other computer' and get the data off of it? Answer - yes.
Posted on Aug 16, 2008
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
New hard drive choices
Hello, Bob!
Seeing as I am a 6 year veteran of Dell Tech Support, I should be able to help you out, no problem.
One thing that I would like to let you know is this: according to Dell Support Policy, you ARE allowed to put a non-Dell-branded hard drive in your computer. However, if Dell Support deams that this non-Dell hdd has caused another Dell component to fail, they will not replace the defective product. BUT, since it is HIGHLY unlikely that a non-Dell hdd would actually cause any other failure, feel free to purchase a non-Dell hdd. (I often times suggested that customers take this route because unless you're purchasing a refurbished Dell product, you're only paying for the Dell name.)
Anywho...
There really are no limitations to what size hdd you can install in your computer. Of course, a larger hdd will take more time to process information (Basically, there's more surface area to scan when your computer is searching for a specific piece of information.). Your main thing will be determining if you have an IDE hdd or a SATA hdd.
The Dell Tech website CAN be your friend (support.dell.com). From there, you can view original configuration and even available upgrades simply by entering your service tag (Usually found toward the back of your computer, on a black sticker with white text. It should list your service tag, an alpha-numeric value, and express service code, an all-numeric value).
If I were in your position, I would most likely not go over a 160g or 200g hard drive... simply to keep decent performance.
Hope I helped!
Oct 29, 2008 | Dell Dimension 8200 PC Desktop
Can't install Strat-O-Matic Baseball
This is a Vista thing that MS still has not fixed. However, when the search for driver page pops up click on manual specify location & point it to, (c:\windows\system32 & check the search subfolders), checkbox. Can't say if this will work for you or not. Some it does. Vista is a devil in a blue dress!
Feb 10, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Dec 16, 2007 | Seagate Barracuda 7200.9 ST3400833AS 400GB...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
