Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
How do I have the key on/off switch replaced - Pride Go-Go Ultra X 3-Wheel Travel Scooter
  • 692 Answers
Dad do you want another keyed switch or can you live with a toggle switch? If you want a keyed switch contact the provider that sold you your scooter and have them order one for you Ask iof they can replace it for you. Now if you just lost the key they should be able to get you just the key. If the switch is bad then you can buy an on/off toggle switch and replace the keyed switch with it it should cost you about 5-6 dollars for the switch and you can install it yourself by removing the front tiller shroud and splicing the on/off switch into the keyed switch wires Hope this helps you
Posted on May 24, 2011
  • David Howard Jul 27, 2014
    would you please show me how to do it: yes I can?
Lock key in ignition
The key itself or the ignition switch may be worn & either need replacement. Try w a backup key first to see if both keys are causing the same problem. If all keys cause the same problem then the switch is NG. Call in a tech for replacement.
Feb 18, 2017 | Cars & Trucks
Replace ignition cylinder
The key has to be in the switch, battery unhooked, turn key to start position, insert probe into small hole above cylinder to trip the wedge, and pull out.
Aug 19, 2012 | 2001 Chevrolet Silverado 1500
Key stuck in ignition but it will turn, and steering column won't lock and car won't start.
you most likely have a bad key switch cylinder assembly. you can try to spray wd40 solvent into the switch before you have the switch replaced,but sometimes it's a switch replacement that repairs the problem. have you inspected your ignition key to look for damage to the key itself? try a spare key to make sure it's the key,and not the key switch. you can also try turning the key while turning the steering wheel at the same time to get the key to work.sometimes the switch locks when parked in a bind,such as on a hill,or against a curb and so on. try this 1st before you have the ignition switch replaced. AAA auto club,if you're a member covers part of the replacement costs for a replacement switch also. you may have coverage through a cell phone also.one more thing to try, if you have a tilt steering column,try to reposition the steering wheel to see if you can get the key to turn. remember never force it enough to break your key off into the switch! thank you for choosing fixya.com!
May 13, 2011 | 2002 Chevrolet TrailBlazer
93 volvo 850 gtl.Runs only while key is full turned let off engine stops. replaced coil set, crank sensor, cam sensor .
replace switch on steering column not the key switch there a switch on the steering column when you turn key a rod run from key switch down to this switch
Dec 03, 2010 | 1993 Volvo 850
Can my key be reprogrammed in the ignition
The electronic key which you have only need to programme once, then it will work till get faulty not necessary to re programme there are only one way to re programme, it's only can do with new electronic ignition switch replacement so if you replace new ignition switch insert your key in it and it will take few minute for programme it take all the programme automatically then you can turn the key and start the car,
If you don't have replace the ignition switch but key is not working it's faulty either key or electronic ignition switch, if you have any other additional key if the car start with that key it's very clear it's faulty your key which is not working give me more details do you have the other key and only not working one key like that, however first replace the battery for your key and try if not work put a comment i will give you more details,
Nov 12, 2010 | 1999 Mercedes-Benz E-Class
When you turn the key and start the car it will start but when you release the key the car quits running
This is caused by a defective ignition start switch, this is the electrical switch that powers up the electrical system when u turn the key, replace that switch. The switch is on the back side of the ignition key cylinder, see picture below, cost is about $20.00 for the switch, easy to replace, just take the plastic covers off the steering column
Sep 27, 2010 | 1991 Volkswagen Cabriolet
Remove/replace starter sloenoid
your Ignition Switch is bad here is how to replace it
The ignition switch is usually mounted to the steering column and is operated by a linkage rod.
NOTE On column-mounted ignition switches, don't confuse the switch with the lock cylinder and keys. The ignition switch is not normally visible. On some vehicles, the steering column support has to be removed and the column lowered to find the ignition switch. On others, the switch is accessible under the dash.
f32-17gif.gif The ignition switch is operated by the key switch. Courtesy of Ford Motor Company. To replace the switch:
  • Remove the ignition switch wiring harness.
  • Unbolt it from its position.
  • Bolt the new switch into position.
  • Attach the witing harness.
May 22, 2010 | Jaguar Vanden Plas Cars & Trucks
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
How do you change a key switch in a 2001 chevy impala, the factory keys wont turn in the switch
If your key is worn try getting a new one cut.
The ignition lock cylinder and keys do not contain any coded electronic components. The lock cylinder housing contains the coded electronic components. Changing an ignition lock cylinder or replacing a key is a purely mechanical process which does not affect the vehicle theft deterrent system. To replace an existing key, simply cut a new key to match the existing one. If no keys are available, the lock cylinder must be changed. To change the lock cylinder, simply replace the existing lock cylinder with one of the same type.
If you are unable to operate the ignition cylinder with a new key then you will probably need to replace the cylinder and switch.Replacement of the switch involves reprogramming
The system may be programmed with or without a scan tool.
There is a way to get the cylinder out without replacing the switch but this procedure should be performed by a qualified GM technician as it involves removal of the switch and some precise drilling.
Nov 01, 2009 | 2001 Chevrolet Impala
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
186 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
