Question about GE (PSS26MSRSS) Side by Side Refrigerator
Have GE model TFX22ZRSA refrigerator freezer seems fine but the other side is not cold...have setting all the way up...have unplugged it and plugged it back in..we have vaccumed the under carriage completely
  • 4,323 Answers
Hi
Please check for that the refrigerator fan (inside the refrigerator) whether it is blowing cold air or no air at all. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps... Please post back for further assistance.
Daniel
Posted on May 23, 2011
Model tfx22zrsa - no cold air blowing into frig - how do I check damper door?
Open the freezer side and look on the whole rear wall and see if you see frost on it and is the fan running in the freezer before we go on to the damper.
Sep 26, 2011 | Refrigerators
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Mar 07, 2010 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
