Question about Cuisinart CPT-160 Metal Classic 2-Slice Toaster
One side of toaster does not toast on two sided toaster
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
  • 537 Answers
SOURCE: Russell Hobbs Toaster Model # RH4T9379
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
Posted on Dec 03, 2007
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
  • 14 Answers
SOURCE: Toaster will not stay down in toast position
The toaster lever is held down by a magnetic coil.
It is the small cube shaped thing with the red wire would around it. More than likely the coil is open. Second guess would be the coil is not being energized.
Outside chance the problem could be mechanical and related to the steel plate that will set on top of the coil when the lever is pushed down.
Posted on Feb 18, 2009
ukvacfan
  • 328 Answers
SOURCE: The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Posted on Apr 05, 2009
Why does my toaster ony toast one side of the bread
Because the nichrome wire on one side of the toast has broken.
Its time to get a new toaster.
Mar 17, 2015 | Baking
Toaster not toasting on one side
No doubt the element is out on that side . You may be better off just replacing it unless it has some sentimental value to it . Chances are the element won't be found since it is that old.
Jan 27, 2013 | Kitchen Appliances - Others
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
I have a three slice dualit toaster. Two slots toast on both sides but the third only toasts on one side - is that how it was designed or is there a fault?
No you need to replace the heater of the second center since it heats only in one side, you can buy on ebay and they have instructions o how to replace it
Jun 22, 2011 | Dualit 31213 3Slice Toaster
Toaster only toasts on one side
Please ensure that the "Bagel" function is not selected (LED is not lit up). The Bagel function will toast one side of the bread while only warming the other side.
Mar 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Only toasts part of bread
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Cuisinart CPT-160 Metal Classic 2-Slice Toaster Logo
81 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
