Question about Garmin GPSMAP 76CSx Handheld GPS GPS Receiver
My gpsmap76csx shuts off on its own, and i've changed batteries
Use usb data cable to turn the power on, if power is stable then probably something wrong with the batteries compartment.
Posted on Jun 19, 2011
I was riding and my motorcyle shut off completely. No power at all. I've replaced the battery, fuses and the starter relay switch. Every time I reconnect the battery the fuses blow when I conne
Some positive wire must be stripped and is touching your frame or something that is grounded. It is impossible to know which wire is that from here.
You need to check your wire harness closely all the way for a stripped wire.
Especially under the fuel tank and around the steering tree.
Oct 28, 2012 | 1999 Yamaha V Star 1100 Custom
My wildgame camera model S4 will not power back up, I've changed the batteries twice and checked them with a volt meter to make sure they are good. I've only had the camera for 1yr.
1) memory card slot/batter covert is open
2)batteries are loades in the wrong direction
3) insufficiente battery voltage
4) poor contact between camera and battery terminal
5) swtich is fault, measure continuity.
God bless you
Oct 17, 2012 | Wildgame Innovations S4 Digital Camera
I have a 2008 buell 1125r motorbike...i've got power to the tailights but that's it. the battery has tested fine, i've swapped relays and replaced fuses but nothing changes, wussup?
Turn the key switch in the opposite direction. The key setting you have it in is so you can leave the bike parked on the side of the road with the tail light on as a warning light so no one hits your bike.
Mar 27, 2012 | Buell Motorcycles
I've been having a problem with my 2000
No.dont diconnect the negative or positive battery at all The alternator only produces 2 volts above battery voltage so a total of 14 volts. If you dont have a volt meter get a small screw driver be careful doing this if you can safely access the back of the alternator (without shorting anything out)in the midddle of the alternator will be magnetic. That will tell you its charging or better yet get a compass and put it at the battery positive terminal and it will swing that tell you its charging. You disconnect the negative the whole car shuts off you disconnect the positive the car stay running but produces high voltage and can damage the alternator itself
Mar 02, 2012 | 2000 Ford Expedition
Toyota sienna 2008 sliding door won't shut
Try lubricating the door latch in the door. You can also use a screwdriver to see if you can get the mechanism to move freely.
Sep 14, 2017 | 2008 Toyota Sienna
My cell phone keeps shutting off on its own, and not turning back on, on its own. it is fully charged and i've tried taking the battery out and blowing it off, but it keeps doing this.
Check that the power button isn't stuck partially depressed. If that isn't it, you've got issues inside the phone that are going to require qualified service, or an internally damaged battery.
Jul 06, 2011 | Cell Phones
Garmin GPSMAP 76CSx Handheld GPS GPS Receiver Logo
106 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
