Question about Mitsubishi WD-60C9 60" DLP HDTV
Mitsubisha wd 6039 tv made a pop and wont come back on
3 Suggested Answers
  • 8457 Answers
SOURCE: My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Posted on Jun 17, 2010
archaeology
  • 662 Answers
SOURCE: My Mitsubisha WD 65838 dlp TV has a high pitch
These HD TV sets are 100 times easier to fix when they actually still (mostly) work.
Instead of waiting for the screaming component to fry and die, execute your warranty service, if
you have your original warranty info - or return it to the point of sale, if your TV was
purchased within the retailer's return period.
The squealers are almost always something in the power supply, or the audio circuitry , FYI.
Posted on Sep 04, 2011
6039 keeps blowing projection bulb
Not sure how long you have had this unit. If it is still under warranty your first call should be to the dealer who sold the unit. It may be part of a bad batch. The dealer should take responsibility for replacing the unit or contacting the manufacturer/distributor. Don't let them tell you it's not their problem. They sold you the item your contract is with them. They bought it from the distributor so they deal with them and the distributor deals with the manufacturer so they deal with them.
Are you maintaining the unit correctly? The filters need to be cleaned regularly, especially in a home environment where a lot of dust can clog the vents causing the unit to overheat.
Plenty of airflow is needed to keep the bulb cool so this is vital.
Cheap bulbs will not last as long as original parts but they should still have a 'rated hours value' under normal use.
Apr 16, 2014 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV popped, bad picture and vibrates
The pop was a high voltage arc of electricity that blew some vital components on the main circuit board. The unit is of no use now. Repairs are far more than replacing the TV.
Feb 27, 2014 | Mitsubishi WD-52525 52" Rear Projection...
Hered a pop sound and now tv wont work
From what I researched, after changin a bulb on these TV's some capacitors fail and "pop" on the DM board, You will have to take it apart and re-cap the caps on the DM board 1000uf 10v (4 - 7 of them). This solves the problem in most cases
Apr 24, 2012 | Mitsubishi WD-52531 Television
Wd 65 733 I have read the posts arounf the white spots on screen. I currently have just a small amount popping up. Looking for cheap price on parts and labor. Thx Will in atlanta, ga
normally white spots are whithin the screen. it is also called "panel". it is the most costly part in the tv. but one need to inspect the tv first before making sure it need to be replace. try to disconnect all cables inside the tv by opening the back cover & fix them again.
Sep 22, 2011 | Mitsubishi WD-65738 DLP TV
My Mitsubisha WD 65838 dlp TV has a high pitch squeal coming from the back of the set.
Sep 04, 2011 | Mitsubishi WD-65838 DLP TV
Kenwood ddx 6039/ user manual
http://kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/DDX6019.pdf
this 6039 and the 6019 manual kenwood says its this one maual is for both
here is the pdf goto it and download and save it then print it out ....
http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Car Audio & Video
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Heard a pop and the screen went out?
i also had the same problem but mine kept making a weird sound like a squeky mice or something...so i hit the back of my tv and it just appeared back to normal...try hitting it at the back but not extremely hard. Best of luck!
Oct 22, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
IS IT POSSIBLE TO UPGRADE DDX 6039 TO DDX 7039?
With this post i presume you are on about in dash monitors!
the DDX6039 and DDX7039 will connect in the same way.
however the remotes are different, the 6039 uses remote rc-dv430 and the 7039 uses an rc dv330.
Feb 15, 2008 | Car Audio & Video
Mitsubishi WD-60C9 60" DLP HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
