Question about Plantronics Voyager PRO Bluetooth Headset
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
Good luck from Headsets Direct!
Posted on Nov 11, 2011
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
I have htc windows 8x phone. My phone wont charge! i plug it in and the red charging battery icon doesn't appears, but it wont turn on no matter how long i charge it. i just got my phone 5 days ag
I think you have damaged your charging pin in the phone by mistake either by dropping the phone or while taking the cord out or inserting. I think the best way to get this fixed will be to go show it to the store that you bought it from/microsoft store. Hope this helps. All the best.
Mar 11, 2013 | HTC Windows Phone 8X
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Just shut off the care returned 2 hours later no go got a boost went for a drive left the car running for awhile than it start to get like it was going to stall went on g=for a littlwe while than died....
Hi your problem sounds like the battery is gone and won`t take a charge. When your engine is running the alternator is supplying the electrical power to run the car ( and normally charging the
battery as well )
Even though it seems strange for the battery to go suddenly, it does happen.
How old is the bat. Most last about 5 years with normal driving ( batterys last longer if the car is used every day )
Anyway i hope i have been of some help to you.
John (south Wales UK )
Jul 05, 2011 | 1995 Honda Civic
My chair has been sitting for 4 months in garage. Chair MPV5 was rarely used. When charging, battery charger indicator shows green light. Chair still does not turn on. What should I be doing?
Replace the batteries and charge before use then charge nightly for 20 days Use the chair daily so you can get a good charge nightly to get the batteries operating at 100% After the 20 days If you don't use the chair daily always store fully charged and then charge once a week overnight. Should work fine once you get the new batteries in You will need to get 2 U1 batteries for your chair do not get Wally World or automotive batteries You must replace with sealed deep cycle batteries made for power chairs Hope this helps
May 07, 2011 | NRS Hoveround MPV 5 - Used Power...
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
Plantronics Voyager PRO  Bluetooth Headset Logo
490 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
