Question about Gateway Computers & Internet
The socket where you plug the charger into the laptop is loose and now will not charge. where can i send it to be fixed and how much will it cost? I am in Niagara falls, ONtario
    Sergeant:
  • 395 Answers
Hi
This is typically caused by tension on the plug. For instance, you allow the charger to dangle and hang on the plug. This causes poor contact and the socket gets hot and melts.
If you go to the manufacturers they will charge you for a new mainboard. Your best bet is to take it into a local TV/Hi-Fi repair shop and get a quote.
Posted on Aug 15, 2008
Battery Icon reads. Plugged in but not charging. What's the fix?
Confirm that the charger is plugged into the electrical wall socket and the light on the charging unit is on. Ensura all connections are secure and not loose.
  1. If all is in order and the laptop is still not charging, the battery OR the charger may be defective.
  2. Shut off the computer.
  3. Remove the battery for 10 seconds
  4. Reinstall it.
  5. Try charging it with the charger again. If that works, good. If not, call customer support.
Aug 25, 2014 | Computers & Internet
Proscan 7044K-C tablet won't charge
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Mar 21, 2014 | Tablets & eReaders
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
No power on hpdv1000
You could have a broken power socket where the charger plugs in to the laptop. If the battery is flat and the socket is broken or loose then it wont charge and will be completely dead. If the socket is ok then it should power up with just the charger plugged in, even without the battery plugged in. You could also have a broken wire in the plug on the charger, the end that plugs in to the laptop.
Feb 01, 2012 | HP Pavilion dv1000 Notebook
Hp pavilion entertainment pc wont charge or turn on
Check the charger is throwing out the correct voltage at the DC jack
Do you get any lights flashing at the charger? If you do it indicates that power is not completing the circuit and is being "spat back". This would indicate a damaged charging circuit or possibly a loose power jack socket, if it feels loose as you plug it in, you may need to change the DC socket
Jan 03, 2011 | HP Computers & Internet
Why would the plug melt on an Acer 5315?
Plugs melt when the connections 'short circuit'.
This means the positive and negative energy paths are touching.
Even the smallest AAA or 9V battery will get really warm if your connect the terminals together, and the power supply of a laptop computer pushes more more power (amps) than a little battery.
If it is indeed the power connection of your laptop has some melting damage, I must recommend you have your laptop and its power supply serviced or replaced, and to not plug it into the wall until you do. Fires have started by malfunctioning/damaged cameras and computers.
I hope that helps.
Aug 21, 2010 | Acer Aspire 5315 Notebook
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Laptop wont switch on. power light not on nether when charger plugged in,charger light is on ,on charger
A commom power problem with laptops. To determine if it is the power socket on the laptop is the problem, plug in the adapter into the laptop and wriggle the plug and look at the charge/power LED on the laptop. If the LED flashes as you wriggle the plug then :-
The problem is the power socket on the laptop, it may caused by a dry solder joint and needs to be resoldered or the power socket may be faulty and needs to be replaced. Either way to fix this, it requires the laptop to be dismantled to get at this power socket. Get a quote to repair, as it could cost a few dollars.
If it is a faulty cord/plug on the power adapter, this can be checked with a multi-meter. When you connect the multi-meter probes to the power plug the voltage should be steady and the reading should be slightly higher then the voltage that is printed on the label on the bottom of the power adapter. If the voltages fluctuates as you wriggle the plug then you have a broken wire in the plug. Replacing the plug would not cost much.
If these tests did not resolve your problem, then you could have a motherboard problem. A replacement motherboard may not be a cost effective solution. It may be better to put your money towards a new laptop.
Jul 02, 2009 | Advent Computers & Internet
My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Feb 22, 2009 | Samsung Computers & Internet
Computers & Internet Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
