Question about PSB Image 1B Main / Stereo Speaker
I am looking for a replacement speaker for an Image 1B speaker SET. Cats knocked one of the speakers off the stand and when it hit the floor, the heavy magnet on the back of the speak broke right off. The number on the magnet is W5-14PP 4S/P. I just need the one replacement speaker. Thanks for ytour help, David
  • Shane
    Shane May 03, 2014
    Hello, I know its been a while but I was looking up some drivers I have and this came up so i have the driver your looking for. If you want it let me know at shanesamps@gmail.com
One speaker produces sound, the other does not. I'm wondering if its possible to fix it.
When the unit fell no doubt the wire that connects the two units was damaged and the speaker is not being energized. Check for a disconnect at either end of the wire and check both wires for continuity.
Don't worry - you do not have to buy a new speaker and it is a relatively easy fix.
Aug 29, 2015 | Labtec Lcs-1060 Speakers
Morning I have a set of KEF Q 5 floor standing
I'd suspect a shorting voice coil in the woofer or a loose connection inside that vibrates and presents a wildly varying load.
Disconnect the bi-wiring jumpers and try driving each 'half' separately as a test for tripping the amp.
Jun 07, 2011 | KEF Audio Q55 Speaker
Hi i have a set of 203 JPW floor standing hifi
remove grill and approximately 6 to 8 screws hold speaker to box. Follow appropiate wiring in removal as replacement. Check crossover while you have it appart
Mar 08, 2010 | Sony MHC-RV888D Shelf System
Need to find a cerwin vega 6 1//2 mid range woofer model number v-6f but i would like just the speaker only not the whole floor stand
muz782,
Replacement drivers for home speakers are only sold directly from Cerwin Vega. If you can find one online, it will not be authentic CV.
http://www.cerwinvega.com/contact_us.php
-Chris
Feb 11, 2010 | Cerwin Vega V-6F 6 1/2" 2-way...
Looking for a replacement speaker for my Technics SB-LX7 floor standing 3-way speakers the top speaker on one of them is broken. Model # Technics EAS65PH313A6
OK. I suggest typing the model in on EBay and getting the cheapest one there is.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Technics SB-LX70K Speaker
Replacement speaker (upper) for Bose double Cube.
try a music specialty store or radio shack if you want to only replace the small speakers inside the cubes. If you want to replace the whole cube, there are others out there. Look on ebay and or amazon I think the brand is JA Audio. A knock off of the bose cubes that can be used as stand alone speakers without the module.
Jan 05, 2009 | Bose Acoustimass 15 System
Location for Bose speakers 901
You could, but the boundary effect of the speaker being on the floor will change how the sound is radiated into the room and therefore make the EQ less effective. Best bet is to try to find some sort of stand (maybe even make one out of wood) that put the 901 at the same height the stand would of that came with the speaker.
The speaker and the EQ are designed and engineered as a system.
Look online, the manual for the 901 shows them hanging from the ceiling also as an option.
Dec 23, 2008 | Bose 901 VI Main / Stereo Speaker
Defect woofers
If you can get the same woofers, then yes you should be OK, pull the units, get the part number off the back and then try Google for a source.
If you can't find a exact replacement then you are looking at replacing all of the woofers, rule of thumb is that you do not want to mix speakers, you end up having one speaker sounding different than the other, so what ever you do to one, you need to do to the other. In that way what tonal changes that happen will happen to both speakers and they remain matched.
Now if you need to find replacements, you need to replace with like impedance speakers, and try to find a speaker very similar to what you are replacing. Just don't throw anything in the cabinet, if the impedance isn't correct not only the sound could be bad, but you could also damage your Amp or Receiver.
john
Aug 17, 2008 | PSB Image 4T Speaker
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
PSB Image 1B Main / Stereo Speaker Logo
87 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
