Question about Coleman Grilling
How can I clean the porcelain grills on my Coleman grill?
    Brigadier General:
  • 4,736 Answers
Since they're porcelain coated, the best way to do it, is by placing them in the dishwasher. But, do not allow it to go through the dry cycle. If you don't have access to an automatic dishwasher, soak them in a 5 gallon bucket of very hot water and dishwasher detergent for 30 minutes. Then using a plastic type scouring pad, clean off any remaining particles of cooked on food and /or grease. Rinse thoroughly and air dry, before placing them back in the grill.
Hope this helped you and Happy Grilling!!
Posted on May 23, 2011
My new roadside coleman grill doesn't produce a flame. It heats but not enough to have a visible flame. I am using a 1lb. propane cilynder.
Flames are merely particulates that are heated enough to glow. If a fuel is burning cleanly there will be no visible flames.
Oct 16, 2013 | Coleman Roadtrip Grill LXE 9949-750
The grill grates have to be replaced often because the porcelain comes off. Where can I get another kind of grate to fit the CGB36ru since your price of about $70 times six is very expensive. What keeps...
Hi steve tell...
I would measure the inside of the grill and go to a welding shop and have them make me a stainless steel grate made from expanded metal that would fit my grill and never go back to the porcelain coated grills and their sticking,cracking,rusting again.
It will be somewhat expensive, but it will be worth it and it will be a one time purchase.
Most of the porcelain grills get faults in the porcelain from heating and cooling that allows greases and salts from cooking to seep into and get behind the porcelain to rust the steel grills that the porcelain is bonded to.
That is what causes the porcelain to pop off...the rust.
Please take time to rate me
Aug 31, 2011 | Thermador CGB36RU Grill
How does the Brinkmann grill model-810-2545-w rank I want to get an idea before I buy it & is it a good grill--Ken
The best answers you can get from those ones who already purchase it. Click here Amazon com brinkmann grill (seller with most reviews) and read the reviews. I hope this was helpful. cheers
May 13, 2011 | Brinkmann Smoke 'n Pit Professional...
Are porcelin flavor plates removable? If so, how?
If you're referring to Powder-Coated Porcelain Cast Iron Adjustable Grates. Yes, they are removable. They just lift off the grill. As do the tent shaped Flame Tamer/Flavorizer plates under the grill grates and above each burner. They should be removed regularly for cleaning.
Apr 18, 2011 | Cabana Kitchens CLA480 (LP) Grill
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
Rusted Grill Grate
and why do you want to replace it? just use bit of wirebrush, scarape off biggest bits, wipe rest with cooking oil and use as normal.
after cooking wipe clean (do not wash!!!) and use bit of cooking oil again to preserve it.
Jul 19, 2010 | Weber Q Grill
I just took my coleman grill out for the season and I don't get any propane to the burners. What now?
there may be a problem with the gas regulator,also make sure that the hole in the gas rails are clean form any soot build up
May 19, 2010 | Coleman Roadtrip Grill LXE 9949-750
I purchased new porcelin coated grates. How do I
My grill uses stainless steel cooking grids, so I had to look it up for cleaning porcelain. Here are a few websites that show you how to clean them. Hope this helps.
This one explains it on the 6th item listed titled: How to Clean Grill Grates.
http://www.gasgrillsnow.com/GasGrillHowTo.htm
This one has good overall recommendations for all cooking grid types.
http://grillparts.com/howto/grid.htm
And finally this one can help you as well.
http://www.mhpgrills.com/restor2.html
May 16, 2010 | Weber Genesis Silver A Grill
How do I clean my grill?
Use a grill brush, if you have porcelain grates then use brush for porcelain. If you have cast the wire brush one works great. Don't use wire brush on porcelain it will scrap it off.
Mar 03, 2010 | Weber Genesis Silver C Grill
I have a Colemann 3000 grill which is in need of repair. The grill has been in storage for the past five years. The guts seem to have rusted out. I'll replace the parts, but am curious as to how best to...
Order the parts from Coleman.com or take it to Sears or grill repair person. If you do it yourself, take it apart first so you know wxactly what parts you need. I have the same grill in the same condition. I am replacing the rusted parts and expect it to look and function like new. I got mine to last a little longer by spraying the inside of the grill down with PAM in between uses after cleaning.
Oct 18, 2009 | Coleman Grill
Grilling Logo
108 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
