Question about HP Color Laserjet 3550 Printer
When I print there are smudges on the sides and then begins mirroring words onto the paper
  • HP Master
  • 1,915 Answers
Ghosting and problems on the edges are often caused by a bad fuser. Remove the fuser from the printer and have a look at it. The upper roller in the fuser is the heat roller and it has a teflon cover on it. If that roller looks dirty or has toner accumulated on it or the teflon cover is shorter than the other roller or has visible damage then you will need to replace the fuser. The good news is that supplies for this printer are very reasonable in price.
Posted on May 24, 2011
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
How do I print a mirror image from canon pixma MG5250 mirror image?
In the printer driver settings, where you can select the paper type, you have to choose "other paper" and select "T-Shirt Transfer".
Jul 18, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Toner smudges on paper after printing usually on
check the two levers with an envelope on each, to the left and right of the fusing unit, should be pressed down and not rise up.
Jun 30, 2009 | Konica Minolta magicolor 2400 Laser...
Borderless printing kodak 5500, clear coating business cards
Go to printing preferences of the particular program and then select Borderless . THESE ARE THE SIZE OF PAPERS SUPPORTED IN Kodak printers.
  • 3½ × 5 in.
  • 4 × 6 in.
  • 4 × 8 in.
  • 4 × 12 in.
  • 5 × 7 in.
  • 6 × 9 in.
  • 8 × 10 in.
  • A
  • A4
May 07, 2009 | Kodak ESP 5 Printer
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Smudge mark 2-in wide down right side of each sheet of paper.
Generally speaking, any area that is darkened, is receiving less light. This can come from a lamp that is failing (similar to a fluorescent lamp used for lighting developing a dark end) or a mirror or optical lense that is contaminated with toner.
This may require some disassembly to diagnose and cure.
You may also want to visually check the fuser assembly (often accessible behind a door) to ensure there is no toner buildup on the affected side.
Mar 30, 2009 | HP LaserJet 3600n Printer
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Laser Printer
When the paper is fresh out of the printer, does the ink that looks okay smudge if you rub it with your finger? If so, it means the fuser is going bad. Otherwise, it's probably a bad toner cartridge that's leaking toner onto the paper.
Jun 12, 2006 | HP LaserJet 2100 Printer
149 people viewed this question
Seeker5211
Seeker5211
