Question about HTC Cell Phones
I can set up my htc incredible s to vibrate with an incoming phone call but cannot get it to have any alert for incoming messagesor emails. What do you suggest?
Try going into your settings
Posted on May 23, 2011
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
PHONE DOES NOT RING CAN HEAR A SLIGHT VIBRATE NEVER FELL.HOW DO I GET IT RIGHT!
when a phone doesn't ring out it means that the ringer of the phone that alerts you when incoming calls, messages etc, is bad and will need to be replaced.
Take care.
Jun 23, 2010 | HTC S740 Smartphone
I have samsung e840 it have no vibrate no alert incoming call
Hi, did you set the vibrate alert on?.
If you did set it it will give you a vibrating alert.But if not that means you will have to go through where the ringing to setting alert and set the vibrate alert on.
After setting it and no vibration yet,that mean you will have to replace the vibration inside the phone.
Would advice if no experience with phones, contact an expert technician around you.
Take care.
Jun 15, 2010 | Cell Phones
Cant get the phone to vibrate on a incoming call
Lorraine,Go to Settings->Sound->In Coming->Alert type. Select Melody and Vibration. Or similar settings. But it has to be connected to your In Coming Calls.
Aug 10, 2009 | Samsung SGH-D900 Cellular Phone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
Vibration
Go to "settings"
"Phone Profiles"
For each profile, you can set the Call Alert Vibration level and save it.
Hope that helps.
Jan 25, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Cell Phones Logo
48 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
