My brand new Aquarius + Hotpoint washer/dryer wdf740 has error message F 05 on first wash. Could you tell me what this is and how to fix it? Thanks
SOURCE: hotpoint Aquarius WF740
Hello again update on error f05 was a sock blockage in the black rubber tubing that connects from bottom of drum to the pump it was a easy fix just plastic clips holding it on make sure you turn off electric first lol !!!! all working fine now.
thanks daddonk
Posted on Jan 20, 2008
SOURCE: hotpoint Aquarius wd440
As mine was under warranty, I just had an engineer fix the a problem with the same symptoms. What had happened is a wire had fell out of the overheat sensor at the top of th emachine so it wasn't heating up while drying.
Posted on Apr 14, 2008
  • 11 Answers
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Posted on Feb 18, 2007
  • 1294 Answers
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
Posted on Apr 14, 2007
eagle338
  • 4889 Answers
SOURCE: Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Posted on Nov 03, 2007
Replacing bushes hotpoint wdf740
check the length of the motor brushes.
new are about 30mm long.
should also clean up the motor with compressed air.
Remove the electronic module also do a cleanup in all contacts of connectors. If necessary wash with isopropyl alcohol which can be purchased at a pharmacy.
Dry with a hair dryer.
Do not forget to make reset to clear the error.
(Pressing the start button until all the LEDs light up)
Dec 21, 2013 | Hotpoint Aquarius WD640 Front Load...
Hi ive just installed my new hotpoint WDF740 , im pleased with it but when its heating up it makes a ticking noise . any idears wot it could be ?
That could just be the heating element and associated hardware expanding- providing it's not coming from the timer!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 22, 2011 | Hotpoint Aquarius WD640 Front Load...
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
Jan 24, 2011 | Hotpoint Aquarius WD640 Front Load...
Please can you tell me where is the filter on the aquarius wdf740 is. Thanks
Check the machine water entry inlet point. Un screw the the big knob. You will find the filter inside submerged into the small pipe.
Apr 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
F-05 flashes up and water not draining out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Jun 30, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing machine error 14
check for blocked sump hose filter, this should resolve problem
Oct 15, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
