Neon lights wont work on my side and base speakers
    Brigadier General:
  • 8,546 Answers
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Posted on May 23, 2011
Which is advanced or better : Neon or LED illumination?
LED lighting is more advanced. Neon has a long history, having been used for nearly a century.Though Neon has the brightest lighting capacity, it requires maintenance. Neon emits more energy than LED lights. LED works in any climate. This makes LED a very reliable optionfor illuminated channel letters. They require much less maintenance and are more energy efficient than neon. Neon signs are easily broken. Being made of glass, they leak. LED does not have this problem . Once you get a neon sign, there's no changing it. Custom LED signs can be updated as often as you like, with whatever messages you like. Custom LED Signs Toronto Single Double Sided New Style Signs
Jul 31, 2015 | Neon Sign Inc Old Style New Orleans...
Left speaker wont work on 1999 dodge neon
Sounds like it's time to remove and replace the speaker.
Sep 08, 2012 | Car Audio & Video
My lg neon phone screen wont come one but my keys and vibrations work what can i d to fix it so my screen works again
If i remember right the neon is a slider phone. if thats the case and the phone hasnt been water damaged there is a flex cable that goes between top and bottom. its a common issue for those to go bad and can cause the phones screen and speakers to not function properly, or both.
Nov 20, 2010 | LG Neon GT365 Cell Phone
Eletrical problems
if you take out the instrument cluster,you will find that it has a double sided pc board. the connector will have broken solder joints on the inside of the pc board,so it has to be removed from the cluster housing to see it.resolder the pins and it will be fine.I have seen 50 of those
Jul 25, 2010 | 1995 Dodge Neon
My 10 in subwoofer in my srt 4 neon doesnt seem to work need help
do u have sound but no light?
I ran my neon straight from the power from the amp so soon as accessories comes on they light up!
Run neon wires positive to the amp directly p.con & negative to negative on ur sub outlet!
Mine had the same prob & it was trial & error & that set up works for me & a few mates have done the same!
May 01, 2009 | Kicker 01C8VR4 Car Subwoofer
I am wondering how to install neon speaker rings I have 2 10" rings and i cant figure out how to wire them together, can anybody help me with that?
the speaker neon lights can be wired in directly from the negative and positive speaker wires by simply splicing them. in most casses this also causes the lights to pulsate with the music. in most 12 volt applications the positive and negative wires are generally transferable and do not cause damage when hooked up in reverse
hope it helps
ryan
Jan 03, 2009 | Car Audio & Video
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base,...
when you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Jan 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Speaker Replacement
There should be at least 2 screws that are hiden in the door panel. One around the arm rest and the other down by the light/reflector.
Take those out and the panel should lift up. Becareful there will be a ton of wires that are attached to the door. Disconnect each of these and the panel will be free to remove.
You should have access to the speaker at this time.
Jul 25, 2008 | 2001 Dodge Neon
I need to connect 12v neon to 12 v plug
Well id like more information but lets do something. I got neons under body and inside. All of them are connected to my fuses. what you need to do is connect the ground cable to the fuselage of the car(hidden) so it looks perfect. Then connect the red cable (or positive cable) to any switch where - is or so so you kow what way is to turn it on(buy the switch anywhere it wont cost more than 4 bucks). Then get some extra red cable 26 or 28' would do and put it to around any fuse and from that well go and conect the other end to the O, the switch side where off is selected. Thats it, really simple. :)
If more questions please ask, and make sure neon works before installing.
May 27, 2008 | Car Audio & Video
27 people viewed this question
 Grubhead
Grubhead
