Question about Water Heaters
Element is broken in two on one side, do not want to pull hard on it and break the other side off inside. bad corrosion
Not enough information on type of heater.
If you have tankless water heater, I doubt that a heater with that amount of crud will operate again. Let us know what happens.
If you have tank-type, then pull the element out.
If it breaks off, it breaks off.
Then use shop vac to clean out the sediment.
Loose parts left inside the tank can bang around, but you will replace the heater in a few years anyway, and you have to remove the bad element or replace the heater today.
Open following link for illustrations:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 23, 2011
Where can I get a bottom element for Montgomery ward 500 series electric hot water tank?
You can get a universal heating element at your local home improvement store. Take your old one with you. If you have hard water I would get one for hard water. Another thing you need to check when you pull out your bottom element is to look inside and see if you have lime build up. If you do you need to get it out. I used a shop vac and got a peace of pvc tube and heated one end and made a bend on it so you can touch the bottom and suck out the line. On the other end wrap duct take around the tube till it fits snug inside of the shop vac hose. If you don't get the lime out you will burn your new element out. It has happen to me. I hope this helps.
Jan 14, 2017 | Water Water Heaters
Can you wire up the heating element in a hot water heater wrong
you can indeed here are the steps to check you eliment
Turn off the breaker inside your main electric panel providing power to the water heater. Most electric water heaters use a 30-amp double-pole circuit breaker.
2 Look for the panels attached with screws to the side of the water heater. Depending on the size of the water heater, you will have one or two panels. Remove the screws from the panels to release them.
3 Remove the insulation you exposed when removing the side panels. Depending on the age of the water heater, the insulation is fiberglass or closed-cell extruded polystyrene foam. Wear safety goggles and gloves when removing fiberglass insulation.
4 Pull the plastic safety cover from the element face. This cover snaps on and off the element and thermostat.
5 Hold a noncontact voltage detector next to the wires connected to the element face, and next to each wire connected to the thermostat. If electricity still is present in the water heater, the voltage detector emits an audible alarm and its light flashes.
6 Loosen the two element screws. Remove the wires from beneath the screws. Make a note of the element wattage printed on the side of the element face.
7 Turn the dial on a multimeter to Rx1k (resistance times 1,000 ohms). Touch one of the screws on the face of the element with one of the multimeter probes; place the remaining probe on the remaining screw. A 3,500-watt element should register 16 ohms, a 4,500-watt element should register between 12 and 13 ohms, and a 5,500-watt element should register between 10 and 11 ohms. Replace the element if it does not register on the multimeter.
8 Leave one of the probes touching one of the screws on the element face. Touch the other probe to any metal part of the water heater. If the multimeter needle moves, the heater element is grounded, and it must be replaced. Make sure you test both screws on the face of the element.
9 Touch each screw with one of the multimeter probes. Place the remaining probe against the metal base attached to the element where it enters the water heater. The element is bad and must be replaced if the needle on the face of the multimeter moves.
10 Attach the wires back to the face of the water heater element. Snap the plastic cover back over the thermostat and the element. Reinstall the insulation and attach the panels to the side of the water tank. Turn the breaker on to the water heater.
Things You Will Need
  • Screwdriver
  • Safety goggles
  • Gloves
  • Noncontact voltage detector
Mar 06, 2015 | Water Water Heaters
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
Jan 09, 2015 | Water Water Heaters
Is the junkers WR 11 Gas water heater ok for outside mounting
No all water heaters need to be mounted inside. Helps with the equipment efficiency, corrosion due to exposure to the elements, possibility of incoming water freezing. It\'s bad on electrical connections, the UV lite is hard on any plastic parts. These things are meant to be installed indoors.
Dec 04, 2014 | Water Water Heaters
Over heats and shuts off
The top thermostat controls your water heater meaning if it is not working you wont have any hot water. If the top t-stat needs to be reset by pushing button in then check the element with POWER OFF and remove wires from element. check ohms should be around 12 to 19 ohms. If ok then reconnect wires and check amps. turn on power and use clamp on meter for amps. 15 to 20 amps should be ok. if not drain heater and pull out element. while you are at it drain all the water and pull lower element. if replaced and you have some hot water then quickly cool or cold then you have a broken dip tube located under the cold side of the supply line. they are cheap and easy to replace. I hope this helps.
Apr 19, 2014 | Rheem Water Heaters
My water heater in my toy hauler doesnt lite and the switch in side doesnt lite up when switched to on
Check to see if you have power at the switch, if there is power there check at the heater. If there is power at the heater, check the controller. If there is power at the controller and after it (at the element. You have a bad element. Normally if the element is bad you are better off replacing the whole heater as the tank may be ready to fail because of corrosion from bad water. You can replace the element and save money, but my advice is to replace the water heater. I hope this helps.
Apr 03, 2012 | RTO Atwood DSI-RV Water Heater-6 Gallon
Keeps blowing circuit breaker
The most likely malfunction is that one or both of the heating elements have shorted out. The elements are not that hard to replace but does take large wrenches. The elements can be purchased at Lowe's or HD.
NOTE: I would recommend you replace both heating elements since they seem to go about the same time.
Jun 19, 2011 | Reliance Water Heaters
Hot water heater keeps tripping circuit breaker
There are two heater elements, one close to the bottom of the tank and one close to the top. One of them have shorted and you will need to replace it. They aren't hard to replace but you will need large wrenches to do it. Most home improvement stores stock the heater elements and are usually cheaper than appliance parts stores.
Jun 15, 2011 | General Electric Water Heaters
I have a rheem water heater and only get to take a shower for 15 minutes at most. I thought that there could be a broken dip tube but don't know how to take out the old one. Is this the problem or is it...
One of your heating elements has gone bad, You need to replace it. I don't know how you check it without taking it out, a trip to the hardware might be in order, You might check the voltage to the heating unit itself before going through the trouble of turning off the water and draining the tank. Then check the line, make sure your voltage is correct, if it is, then remove an element and match it up at the hardware store, if they test it for you and it is ok, then you put that one back and replace the other one. I am not sure but I think an ohm meter will tell you if it is good or not. Check it out. The tube you refer should only disintegrate, they only break when you drop the unit on it's side. They last quite a while. Hope this helps.
Mar 13, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water tank - the hot water shuts off even though there is power to the device
The circuit breaker keeps getting thrown yes? Alright then, you may have a bad element inside the water tank. If you don't know what a circuit breaker is then please call a plumber and do not go near the water heater as it may be a danger to your well being. However, if you do know, then go out there and throw the breaker to the water heater. If you are not sure about this or can not test the voltage at the water heater then do not proceed. However if you are sure, then take off the little covers from the side of the tank and look at the insulation as it may appear moist or wet. There is a heating element inside the tank which can break off, cause electrical shortout and allow water to leak out into the insulation. How to Fix: Shut off the cold water supply at the top of the water heater, then go to the nearest sink and turn on the hot water. There should be no water pressure if you shut the supply valve going into the tank. Now then, leave the hot water turned on at the sink as this will provide a vent for draining the water from your water heater. At the water heater there is a small valve at the bottom which when opened will drain the entire volume of the tank. I suggest that you find and connect a hose to this valve prior to opening it so that the escaping water goes outside rather than on your floor or you could just call servpro and let er rip. Either way, while the tank is draining look on the side of the water heater and find out if it is 240vac or 120vac and write this down. Now look to find the wattage of your heating elements. It might be 1500 watts, 4500 watts or 5500 watts, write down the wattage indicated for the heating element you are about to replace. Write down the brand and the model number along with the voltage and element wattage and go to your local hardware store. Ask one of the older guys (not the kid in electronics) if they would help you select the proper heating element for your make/model and also ask if you need an element wrench to install the heating element which you are purchasing. If the answer is yes, then get that to as you will be needing one very soon. Back home your tank should have drained completely. Now on the face of the old element will be two wires; remove them. Take your nifty little element wrench that you just bought and remove the old element. You will probably be amazed to find that the old element is like, in two pieces, and that's because the rest of it has fallen off inside the tank. If you can retrieve the part left in the tank then do so however it will not be a problem if you can not. Disregard the white hard water build up inside of the tank unless you have the time and capacity to dig all of it out through that little hole. Although, you may need to wallow it out a tad so that the new heating element can fit inside. The new one will replace just as the old one was removed and do not over tighten (it just needs to be snug not twisted off). Replace the two wires; either way don't matter. Then shut the drain valve and open up the water supply on top. Your hot water tap in the nearest sink should still be turned on and now you should hear the air escaping from inside the water heater tank as it is being filled with acid. No just kidding, it is filling with cold water. When the tank is full, water will run from the tap and only then may you shut off the tap. Now with the tank full and the new heating element wired up to the thermostat you can throw the circuit breaker back on. Congrats. Within in 30 mins you will either have very hot water or you will hear an explosion louder than anything you have ever heard in your life. As long as you followed the filling the tank till the water runs out your faucet bit, you should be good to go; go take a bath that is.
Aug 10, 2009 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
