Hello, I have very old IBM ThinkPad laptop that I never use anymore. Now I remembered that I have some files on it I have to get (also websites that I had put on favorites). When I try to turn on the computer this text comes up: Broadcom UNDI PXE-2.1 v7. 7.5 Copyright (C) 2000-2004 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation All rights reserved. Broadcom Base Code PXE-2.1. v1.0.1 Copyright (C) 2000-2004 Broadcom Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broatcom PXE ROM Operating System not found Is there something I can do? I really need those files :/ I would be so grateful if you could help me solve this problem. Thank you, Soley
  • 4,806 Answers
Hi.
I think the boot order on the laptop has been changed and the laptop is trying to boot from the LAN (NIC/Ethernet) port.
To change the boot order you need to access the BIOS. On older IBM laptops (and this is dependant on the model) the BIOS Utility is entered by holding F2 while the ThinkPad logo is displayed after power on, or, with the unit powered off, hold the F1 key and power the unit on. Keep F1 held down until Easy setup appear. The key is either F1 or F2.
On other models there is a blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
once in the BIOS look for the boot order of the computer and change the boot order to the HDD (hard disk drive). There will be instructions on the screen on how to change the boot order. Save the changes and restart the laptop. Hopefully it will now boot into the hard drive and load the operating system.
Hope this helps!!!
Regards.
Posted on May 23, 2011
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: I brought the computter about month ago.. and now its appears ::
This is a common problem but there may be more than one fix
The easiest is to go to your bios and set the boot device order.
It is quite conceivable that it is set to try and boot from network first
You should select HARD DRIVE or CD DRIVE as you first option and then reverse that order for your second boot device
Posted on Aug 20, 2009
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Apr 04, 2010
  • 162 Answers
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
I need a new modem for a 2001 ibm think pad 2628 need a price.
I would check ebay, as that model is too old for IBM (which doesn't make laptops anymore) to have that part in stock.
Mar 01, 2011 | IBM ThinkPad A21m 2628 Notebook
Hello Ive got an IBM thinkpad type 2652 copyright 1981-2001 by ibm corp. my first problem is that disk c doesn't work anymore and I had ti install windows on disk d instead, however, it is extremely...
Your hard disk in all likelihood is just a single partitioned hard drive so it gives c and d. From your description, it probably need replacing, just replace the harddrive and buy a usb cd/dvd drive
Aug 27, 2010 | IBM ThinkPad A31 Notebook
No audio output
For my Thinkpad, when I bought it used it had the same problem. I went to Lenovo's website and found my Laptop from the list. Then I choose a "System Update" file, downloaded it and it told me all the drivers were wrong from the video to the sound card. I downloaded all the files and installed them and presto every driver was perfect. During the install you will have to note all the old versions as they will have to be uninstalled either first or during. IBM Thinkpads are bullet proof and 100% restore-able to factory settings with their drivers from IBM (or LENOVO now)....do not get them from anywhere else. The person that sold me the laptop told me the laptop worked bad, so he gave it tom me cheap..and now 3 years later, its still running perfect. Hope this helps.
Jul 01, 2010 | IBM ThinkPad T43 Notebook
How do you dismantle a thinkpad?
though it at a wall NO lol, there are screws located on the bottom and back near hindges and under battery also under the keyboard, but start with bottom as there is one there that holds the keyboard on
Feb 12, 2010 | IBM ThinkPad T23 2647 Notebook
Drivers for Network controller, Video controller, Wireless
Please visit IBM website and you can see the driver files in that site
Apr 04, 2009 | IBM ThinkPad T60 Notebook
About video card
Hi Mina!
Follw the link bellow, download the video file and install it
http://www-307.ibm.com/pc/support/site.wss/MIGR-57669.html
Thats all avalible files for you t23, if you need anymore drivers, just download and install them
Good luck to you!
If you find my answer helpfull, dont forget to vote!
Dec 19, 2008 | IBM ThinkPad T23 2647 Notebook
Free ibm t21 2647-4bu restore cd download.
If your system is working and you can get the internet on it then you should be able to access all the required driver updates available via the Lenovo web site here :-
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=50268&brandind=10&doccategoryind=0&modelind=79050&doctypeind=9&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=78825
This Address is specifically for your machine type model.
Aug 21, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
290 people viewed this question
David Payne
David Payne
