Question about EliteGroup P4VMM2 Motherboard
Read frequency noise in speakers
When the computer starts, and is proving frquency I hear a noise in the speakers, and port lpt1 is out of service. Some can help with this problem?.
I supose the problem was generated for bad memory conections.
Thanks a lot
mafw1
  • Anonymous Aug 31, 2008
    Thanks a lot, I don't understand what is a vstick.
    I thnkyou be more specific
    mafw1
  • 3,051 Answers
You can try to take out 1 vstick at a time and reboot and see iof the problem still occurs that will help you do a process of eliminatiion fix
Posted on Aug 21, 2008
SOURCE:
How do I stop feedback through speakers
Well, a feebackback destroyer is oke, or a good equalizer, no cheap noisy one and take one with 31 channeles /channel and lower the trequencies where about where you hear it lower frequency frequency by frequency, until you have the frequency which gives the problem and keep the frequency low in volume . But there are more ways, like replacing you monitors a bit. A low noise graphic equalizer ain't cheap. I thought ART has reasonable anti feedback surpressors....
Oct 07, 2014 | Philips 2.1 Multimedia Speaker System -...
Where can i find the frequency of motorola gm338
This is a business band 2 way radio and you would have to connect it to the programming software and read it or use a frquency counter
Jul 31, 2014 | Universal Motorola GM338 Rapid Six-Bay...
On my radio I need the settings for the knobs because other people can hear me but I only get static and cannot hear them. Thanks
Band should be E Band high/low button on high 10 khz off AM selected
To check that you have done this correctly frequency counter will read 27.185 plus or minus 5 khz. This is of course proved you have a radio that is converted for 11 meter cb frequencies.
http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm Frequency Conversion is the channel expansion mod/conversion
Sep 16, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Hello! I was recently playing and found out then whenever I play specific notes on any of my guitars, my Fender Frontman 212R will buzz. The notes that always buzz are drop C, drop C#, any A note, and...
There is something resonating with that note frquency. Often the grille or wiring inside will rattle at certain frequencies. You need a sustained source of these frequencies to find what is causing the noise.
Aug 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
JRX125...there was a rattle/noise that indicated blown driver on midrange horn...replaced drivers, noise still occurs. discovered loose 1/4 in jack to tip of plug...tightened fit, but didn't trust...
The noise MIGHT be a resonance in the cabinet. The way to find out is to sweep a frequency upward to see if something rattles at certain frequencies... Don't be surprised to find several. Within the cabinet are the usual culprits: Wires rattling against the cabinet, loose debris, grilles and the logos on them, circuit boards with crossover hardware, cabinet wood that is not glued and rattles against itself. Things like bass port tubes can rattle.
Find an audio generator and sweep the cabinet from 50Hz to 10KHz and you will be surprised. Some speakers may have resonances as well. Expect things in your room to start rattling as well.
This is really the only way to find the problem. PLEASE wear hearing protectors at levels above 90Db.
Mar 27, 2011 | JBL New Jbl Jrx 125 Dbl 15 2 Way Speaker...
My Samsubg PN42 was built in Sept 08 so no more warranty. Speakers rattles with low frquencies. OK when listening through receiver. Does anyone knows aproximate cost of replacing speakers in a flat plasma...
The problem is inside of the tv. Your speakers are probably fine. The problem in most sets I have found is that the internal parts/Brackets are vibrating particularly at the lower frequencies. You must insert non conducting foam and duct tape to immobilize any moving parts. With the back of the set off, Tap the chassis with your finger and you will hear where the vibrations are coming from. Repeat taping and inserting the foam until the vibrations stop or are minimized to acceptable levels. You can also adjust the custom audio with the equalizer to cut the base frequencies. This is a common problem. In some cases I have found Bad speakers and need to be replaced and is really simple to do with the back panel removed. Once you see the speakers you will how simple it is to replaced the speakers.
Apr 15, 2010 | Samsung Televison & Video
Unable to scan -- I think I downloaded software for Dell 926 and rebooted, turned off printere, back on again, no luck. Help! JJB
we have a hewlett packard t45. We got a new computer without a lpt1 port, so we got a usb cable. Now it will only print, the print requires a lpt1 port to operate properly. The new scanners and all-in-one printers use a usb cable. I had to got to the manufactures website and do some searching and reading to figure it out.
Aug 07, 2009 | Dell 926 All-In-One InkJet Printer
I have a HP Officejet All-in- One. Fax won't go through
We have a Hewlett packard officejet t45 all-in-one. We recently bought a new computer that didn't have a LPT1 port, only usb ports. So we bought a usb cable and now it only prints. I then went on the Hewlett Packard website and did some searching and reading and found that our all-in-one printer requires a LPT1 port and cable to work properly. If that is the same with you, you can buy a LPT1 card with the port to install in your computer.
Aug 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Switch to LPT1 from my computer
Go to start - settings - printers and faxes
Right click on your printer - click properties
At ports tab change from tcp-ip to LPT1
Click apply
Don't forget to connect your printer with parallel LPT cable
Jul 24, 2009 | IBM 6400 Matrix Printer
Oki C5150 Not Communicating with Computer
lpt1 usually only works for parrallel printers unless a USB port has been mapped as lpt1.
Is this being installed on a Windows Vista computer?
Jun 19, 2008 | OKI C5100n Laser Printer
EliteGroup P4VMM2 Motherboard Logo
20 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
